Under (Front) Bumper Warning Sensors or Cameras... Ideas Please
These cameras are very robust since they get hit with stones, mud and water.
Maybe get one and mount it somewhere back onto frame or such where you can see forward and line it up with bottom edge of chin spoiler so as you get close you can see if curb is too tall and when to stop.
would need small monitor as I doubt you could feed it into existing system.. maybe someone makes a BT one so shows up on phone?
Given the electronic complexity of these cars, I think it prudent for the moment to experiment with a standalone system that does not require more than power from the car, and does not connect to other systems. I still haven't decided whether to try a camera system, or a simpler radar system, which can be positioned below the bumper and aimed at a downward angle. The idea is to limit any beam interference with the parking sensors in the bumper above.
My wife's car does not have a sensory system, but does have the same curb stop problem. So I might start there. Had the system in the OP come with all the required parts as advertised, it would be installed by now.
Thanks again for the ideas.
My car has 4 parking sensors and the system would work just fine with one of the middle ones missing. And my parking sensors often see the wheel stops too but not always.
All we need is to ask our friend Konigstiger to find the parking sensor loom illustration and part number (LOL). I've looked at a couple part sites already, and am not sure what I should be searching for. Parts I'm finding are not labeled as I would expect.
I also wonder if a new sensor will need programming for the system to recognize it? If programming is involved, then the fallback option is to move the entire sensor below and 3D print a backing for the outside button left in the original location.
Lots of "ifs" involved here, just as with the other options.
So I think I will consider sensor systems that don't interact with existing features of the car.
And congratulations for your car of the month nomination. Your car/you really deserves it!
Have you checked that you don't have some sort of radar sensor behind the grille in front of your car. They may have built the car with the Distronic radar sensor but it is used only for the FCW.
Honda, I think< use the camera in the windshield for this.
https://www.mbusa.com/mercedes/techn...00ccec1e35RCRD
In contrast, an independent system can be easily installed, and easily removed, if it doesn't work well enough.
The diagrams you posted shows my sole area of interest, the "Area not scanned" at the front of the car. The external sensors described in Post #1 make good sense, even if it means to point the sensor at a downward angle to limit/avoid interference with the bumper sensors.
With the passage of time, there are now several cameras that wirelessly (WIFI) send signal to one's smartphone (IOS or Android.)
Here is an example. One of the reviews is from an SL500 owner who successfully uses his under front bumper...
Review...
Product...
Thinking about where to find power at the bumper, I am wondering if I can install power for this in series (spliced into) my illuminated grille star... Thoughts?
Fixed... (see post #17 above for the "before" pic)
I've ordered the camera above, yesterday. It will arrive tomorrow. I've already installed the Casoda App on the smart phone, and it appears to work well, offering both landscape and portrait display modes. I'll do some testing before installing the camera under the front bumper.
I'll post some pictures here... if anyone is at all interested?
It's aperture is small enough that I think it will shoot through the diamond facets in the grill (mounted from behind where it's hard to see).
So now, the question is how to remove the black, lower grille to find mounting areas behind. This grille is part #200 on the front grille schematic (below), but the drawing shows no fasteners to explain how it attaches to the painted bumper.
Is this grille just a pop-in that can be removed from the front (without removing the bumper)?
Please excuse the dirty car... It needs a wash...
This would be preferred, so as to keep all the bumper/grille parts in place. This way, I can create an adjustable bracket, attach the camera, and tune the aim of the camera (through the lower grille) as I go.
Has anyone removed the engine splash shield? To drain engine oil from below? Is it as simple as it appears?
(I couldn't replace the lower grill on my C class without removing the bumper cover.) But, I think you should be able to access the lower grill to mount the camera from behind. I hope you are successful on the E.
BTW, one of my initial concerns about a wireless camera was the possibility of poor transmission past the engine, firewall, into the cabin, etc. However, this kit may have this covered. Included in the package (but not shown on Amazon) is a remote WIFI antenna with 78" cable. It plugs into a 10" pigtail from the camera, allowing 7-1/2 feet of cable to position the antenna above the engine and closer to the firewall. A separate power cable provides 10 feet of length, hopefully enough to reach the driver-side fusebox, where I can add it to the existing wiring for my aftermarket illuminated star.
Today is Thanksgiving, so I am busy with family commitments of course. Tomorrow (or the weekend), I hope to wire up all the components close to their anticipated installation positions to test how it works to my smartphone (before trying to install in the car). One step at a time.
Then I installed the round, WIFI antenna on the passenger's side vertical wall next to the cabin air filter intake above the battery. Reception from this place through the firewall to my smart phone mount on the dash air outlet vents (no more than 3-4 feet away) is superb. In this location, there is plenty of wire leftover to route to the proposed location in the lower bumper grille...
I also wired the power (+) to the fusebox, piggy-backing on my existing fuse tap for the Illuminated Star. And there remains plenty of wire to route under the bumper as well. The negative wire is grounded to the top of the shock tower. Retest and everything still works.
Two hours later it's dark, leaving me to plan the next steps for Sunday, as it will be raining tomorrow. The next step is to finalize the routing of the cables to the lower bumper grille area. But more important, the really major step is to put the car on blocks so I can get my 70 y-o carcass under the car, remove the engine shield and test camera installation ideas. Stay tuned.
