Sponsored by: CARiD
Will 2014 E550 wheels fit a 2014 E63
Old May 4, 2019 | 06:25 PM
moncini1956's Avatar
2014 E63S
I am going to powder coat my E63S 10 spoke rims. I have a set of Concept One’s from my old E550 i’d Like to mount on the 63 in the garage while my AMG rims are being coated. Will not drive the car, just need to get all 4 tires off it for a week. I’ve got carbon ceramic brakes, interested to know if those rims will mount up temporary.
Old May 4, 2019 | 08:47 PM
Buffalo MB's Avatar
2014 E550
Running the numbers through a wheel offset calculator you are losing clearance going to the E550 wheel. Don't know if they will fit, but I wouldn't risk it. Can you put it on jack stands and store the car where no one will be near it?
Old May 5, 2019 | 02:04 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Generally MB is pretty tolerant to wheel swap and I have changed them several times different ways.
Even my W212 in sport package come on 18" wheels, I already measured that 16" wheels from W211 fit on it just fine. Offset is different, but suspension still will accept it.
Good luck with your fitment.
Old May 5, 2019 | 07:54 AM
RA72825's Avatar
The only issue would be clearing the front calipers and I doubt that is a problem if they are the stock 18” AMG wheels. The offsets are close enough. 45et vs 50et and 37et. I am using the 10 spoke E63 wheel on my 550 4M.
Old May 5, 2019 | 09:44 AM
2014 E63S
Thanks. Both wheels are 19”
my biggest question are the front calipers on the 63. Easiest approach would be use on back wheels, jack up on center point under engine and put the front end on jack stands.
Old May 13, 2019 | 06:21 PM
2014 E63S
Won’t work. Front disc dust covers won’t clear the rims. Carbon ceramic brakes are huge. Oh well, was a good idea. Back to the drawing board. L
