M276 ticking noise
2013 E350 with 35k miles. Been doing as much research on here as I can before posting. Seems like it could be the timing chain? The ticking speeds up when the RPMs go up so hopefully that isolates it to the timing chain, although I'm not familiar with MB at all yet. Anyone with knowledge of the M276 have advice on what the common flaws are with this engine? Thanks
Sure it is not exhaust leak?
Originally Posted by ygmn
(Post 7801528)
All the M276 direct inject engines make a ticking noise from the injectors. This can be heard when the hood is up and you're close to the engine compartment, but shouldn't be noticeable inside the car. The only way to be sure whether your ticking noise is normal is to take the car to a dealer or an indie MB expert. Or, I suppose you could go to a dealer lot as a 'prospective buyer' and ask to listen to the engines of some M276 used cars just to get your own comparison.
Originally Posted by Kilt
(Post 7801724)
I've had both the water pump and the HPFP replaced under ELW for ticking noises like this.
Agree with Kilt that M276 direct injection engines tick more than non-direct injection gasoline engines. Quasi-diesel sounding. I can hear it in the cabin. W166 GLE350.
Originally Posted by chassis
(Post 7802140)
camou, yes it doesn’t sound like the old (non-DI) normal.
It is, however, the new normal. |
(Post 7802176)
