E550 18" Alternative Tire Sizes
Also, you're the one that initially said you've seen 255s up front with some success....am I wrong to take that information as useful? Because now it definitely sounds like you've backtracked on that idea and that I don't understand it's because the E63 has wider fenders...
Ah, the Czech Republic. Formally Czechoslavacia of the former Soviet Union. Not known for their "wheel-manufacturing" prowess...lol
Take you car and have the rims put on a balancer to ensure they are straight, easy enough to see while it is spinning. One of mine was cracked and getting worse by the day. I had no choice but to buy new wheels. If you can't feel them(I could) then you'll probably be fine for at least a set of tires, depending on how you drive...
These are the OEM E63 AMG 19” wheels.
I like the look of these BBS bespoke designed wheels for the E63. Since they are OEM, there are no fitment issues, other than I did not want to risk running the 255 up front.
The front offset pushes the wheel out towards the fender. It is an ET37 vs stock ET48.
The rear offset moves the wheel inward a smidge. It is an ET52 vs stock ET48. The 285 width is not a problem.
These are very difficult wheels to find and can easily cost $2500-$3500 for a set. There are cheap copies out there, but they are junk.
10" is definitely doable on the rear, not sure about 10.5 though...
EDIT: Also glad u posted info about the up front offset. So you can go a tad bit more negative in the front so as to not clip the suspension. You have any photos of your fronts? Would like to see your clearance. I'd probably try n stick around +37 since I haven't seen many figures on what the min and max should be when playing with offset.
E63 AMG 19”
If you zoom in on the front you can see that the 245 wide tire on this wheel and offset is right at the edge of the fender. A 255 wide tire would poke beyond the fender. On the rear I could probably add a 15mm spacer to push the wheel further out as there is room to do that, even with the 285 tire.
E63 AMG 19”
But the fact you could probably add a 15mm spacer kinda clarifies there's possibility for 300-305mm width in the back. At least on a wider wheel. Nice setup btw.
I run a 285 on the rear on a 9.5, but with more offset so I'm actually flush with the fender. I'll try to remember to post up a couple pics to show you where they sit.
I'm actually debating on either buying some 17's for the rear and getting 275/45 drag radials or just going with some Toyo R888R's in 235/35 and 265/30 on my 19's. I know the smaller diameter 19" tires would be slightly beneficial for 1/4 mile times, I'm just not sure about driving on the r888r tires daily....swap tires around all the time, or just get Toyos??? Decisions, decisions...
Yes please post pics. That would be great.
Ugh I know. I thought about just sticking with 18s when I get wheels now....but at that width it's looking like I'll have to go with 19s possibly
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
I've set the fender clearance where mine will rub and you can see there is 17mm clearance on Key's wheel(this is just a representation since it is actually the tire on my car that rubs). So I may have been mistaken on being able to fit a spacer on the AMG wheel as I honestly did not expect that much positive offset...+52 is a lot!
