Sponsored by: CARiD
common problems and things to look for W212
Old Aug 9, 2022 | 01:48 PM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
Originally Posted by cetialpha5
The W212 never had a 4 cylinder, that was the later W213 which started in 2017. Basically you either had the M272 which had 268hp in 2010-2011 or the M276 in 2012-2016 with the 302hp in the E350. The E550 and E63 had V8 engines, even the E400 was 6 cylinder.
Newer to Benz cars, but isnt my 2014 E250 a W212? It has a 4 cylinder diesel in it.
Old Aug 9, 2022 | 01:53 PM
cetialpha5's Avatar
Originally Posted by Quint22
Newer to Benz cars, but isnt my 2015 E250 a W212? It has a 4 cylinder diesel in it.
Oh yeah, that's the diesel, meant 4 cylinder in terms of gas engine. Diesel isn't too popular. Don't really follow them, They have various other issues and it's hard to find anyone besides a Mercedes dealer that would know anything about them, that's the main problem with a super low volume car. Good luck finding aftermarket parts or used parts specific to the diesel also.
Old Aug 9, 2022 | 02:24 PM
Quint22's Avatar
Veteran: Navy
Luckily the sprinters have the 2.1 diesel and the V6 older brother as well so those are pretty common. My car the E250 apparently isn't very common in the states, then VW/Cali/CARB/EPA killed the diesel car industry over here. I still see a lot of the E350/E320 diesels and once in a while one of the SUV types in diesel. After market parts (OEM replacement) seems to be ok, performance parts not so much atleast here in States. Just FYI my experience so far.
Old Aug 9, 2022 | 02:27 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
there are indeed 4 cyl gasser W212's in .EU, E200, etc.
Old Aug 9, 2022 | 03:57 PM
cetialpha5's Avatar
Right, but I got the feeling that the OP was in the US and we never really talk about the gassers in Europe as this is primarily a US based site.
Old Aug 10, 2022 | 12:57 PM
Jack McCarty's Avatar
2011 E350 4MATIC Estate Wagon
Consider replacing shocks on pre-owned E350 W212
When I bought my 2011 EWagon, with 100k miles, I found the ride harsh, but both my Indy Mechanic & local MB Dealer said shocks were ok, as they weren’t leaking.
I didn’t agree & bought OEM Bilstein set of shocks on eBay for $500 & had my MB Body Shop install.
what a difference!
it makes sense to replace shocks on a 10 yr old Wagon with 100K!
Old Aug 15, 2022 | 06:42 PM
  #32
SAM Satellite Module Failure / 2011 E350 4MATIC Wagon
Forgot to mention that when the front
SAM Satellite Module fails, forget the Indy Shop & DIY!
This pricy part ($800)when failing
can immobilize the vehicle, & can only be linked up by Satellite with a MB Dealer Mechanic.
My Indy Shop couldn’t figure out the problem & cost me a LOT in diagnostic time - like $800!
I never saw MBWorld discussion, but lived through the breakdown & want to spare others the limbo of ignorance as to the Satellite issue!
Old Aug 15, 2022 | 07:28 PM
  #33
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
It's bit odd MY'11 has satellite built in the F-SAM... and FL uses a separate module in the left side of trunk
