Sponsored by: CARiD
Hesitate upon acceleration
Old Sep 12, 2022 | 12:06 PM
Harr Suter's Avatar
Mercedes 2016 E350 4matic
My 2016 Mercedes E350 4matic hesitates upon acceleration and when in 5th gear. What could be the cause? Can anyone help or have had or have this issue.
Old Sep 12, 2022 | 01:04 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
car acting up.... gently
Hesitation during acceleration from lean mixtures or tranny...
Many things can impact driveability: faulty pumps, misfires, low voltage... a specific TSB may be available for hesitations.
Get your car scanned for obvious faults codes before anything.
Tell us about current mileage and service history....
Old Sep 12, 2022 | 02:39 PM
Harr Suter's Avatar
It currently has about 70000 miles, currently been scanned no faults. No major services
Old Sep 12, 2022 | 02:49 PM
...​​​​​​unfortunately nothing obvious.
You're left with troubleshooting from data or the wet finger parts canon
#1: unregulated fuel pressure ?
#2: negative fuel trims ?
#3: ignition misfire ?
Old Sep 12, 2022 | 03:55 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Scanned by? Autozone/PepBoys/AdvanceAuto, or MB-aware scanner? Sometimes there are no "visible faults" unless you get down to the modules and check for stored codes.
Hesitate under mild acceleration, or hard acceleration (like racing off the light)?
If it only happens about the 5th gear, and not other gears, @CaliBenzDriver what do you think about disconnecting both batteries? Count to ... 1 min? Then, reconnect.
Old Sep 12, 2022 | 05:31 PM
Harr Suter's Avatar
only under mild acceleration, takes off fine under hard acceleration.
I will try disconnecting both batteries
Old Sep 12, 2022 | 10:55 PM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
Be sure to do like 10 or 15min, in my experience 1min isnt long enough.
Not sure on your car but do u have sport/eco mode for the trans, does it do it in either or just eco?
Old Sep 13, 2022 | 01:14 PM
Harr Suter's Avatar
I tried the batteries, that didn’t work. Thank you
Old Sep 13, 2022 | 01:17 PM
Harr Suter's Avatar
I will try the batterie’s again for about 15mins.
I have not tried it in sport mode.
Old Sep 13, 2022 | 07:16 PM
Quint22's Avatar
Veteran: Navy
By no means am i expert, i just do know the 4matic kind of learns driving style or some such in eco but think it doesnt use that in sport. Anyhow good luck
Old Sep 13, 2022 | 07:55 PM
blind without data
The car Reboot step is an excellent start for any odd symptoms. Once done you can assume SAM's are back on their best behavior.
Without access to live data... the next step is your local MB specialist who has tools to restore lost performance.
commited forum sponsor 🙏
To skip tall repair bills from the shop, you can catch up with regular scheduled maintenance. Pelican Parts and tools are cost efficient without premium labor involved.
Last edited by CaliBenzDriver; Sep 13, 2022 at 08:57 PM. Reason: sponsor's recognition
Old Sep 14, 2022 | 08:55 AM
bzcat's Avatar
2003 W203 C230, 2021 RS6, 2022 992S, 2024 Q8 Etron
The part that throw me a for loop is only happening in 5th gear. That eliminates a lot of possibilities like fuel pump or engine mounts and points to the gearbox itself. Maybe the gears or the torque converter is starting to fail?
Old Sep 14, 2022 | 12:56 PM
Harr Suter's Avatar
Hesitation upon acceleration
thank you guys, I looked up signs off a bad torque converter and it lines up with what’s happening. I plan to take it to my mechanic to checkout. I will keep you updated.
