Good to unbolt front subframe to make motor mount replacement easier?
Good day all!
I am going to replace trans and motor mounts of my 2010 e350 rwd. The easiest way i could see is the following with link below. Need not to remove any alternator or exhaust pipes etc....
https://youtu.be/07qSy_GHUyo
But, this method need to lose all 4 bolts of the front subframe. I am not sure doing this will be good, safe or not.
Location of the front subframe bolts for reference ...
Any ideas will be appreciated and helpful. Thanks all!
biker349 (11-19-2022)
2013 W212 E350 RWD
Have you tried/considered removing the fender liner and pulling it out from the side? You may have to remove the strut tho. When I removed my fender liner, I just had to unzip some 8mm nuts
