2015 E350 Auto Climate Problem
New to the forum now that we have a new-to-us 2015 E350 4Matic Wagon! Love the car so far but driving the car home the other evening from the dealer (a long drive) I ran into what I think is an issue with the AUTO climate control.
I had it set to 70 degrees, all vents open, no zone activated, a/c on, ECO off, no windows or roof open, and the system was as expected for about 20-25 minutes after start and then suddenly it just started absolutely blasting heat and it wouldn't stop. I obviously tried turning the temp down, all the way to 60, no change whatsoever, until I turned it to LO and then it switched to full blast A/C. After about 30 minutes of back and forth I just gave up on it and turned it off.
I tried the AUTO again after stopping on the way and, same thing - fine for 20-25, then full on Hades.
I contacted the MB dealer, who tried to explain that "it's just a common thing with those models" and to just not use the AUTO function.
I find it pretty hard to believe this is "normal," even my Chevy Blazer in high school had AUTO climate that worked - am I wrong here? If not, is this a sensor that has gone bad and an easy fix?
Thanks in advance!
Thanks in advance!
It sounds like the defrost cycle is going wrong... like the coil sensor has peeled off.
Let's connect a "LAUNCH cReader Elite MB" or equivalent capable scanner to read data out of your AAC Module. See what happens when temps go wild on you.
Whatever you decide don't rush to overfill the refrigerant circuit. Scanner will read you pressure sensor...
Thanks in advance!
We can tell there's an existing coverage in place because "everything is perfect" until the day when every expensive part will need work.
I would go ahead ASAP and pay the $200 diagnostics fee - It's free with repairs, right?
Due-diligence... you should scan the chassis with a good scanner or get good pros involved to check big ticket items tranny, 4Matic-toc, plugs/ cyl. scoring, CPS oil-in-harness...
I don't complain it's the way it works
It appears that a cabin temp sensor embedded in the overhead control panel (where the pano roof control is) shorted out and randomly shows -10C temps. Awaiting the dealer's response, as it's apparently a complete overhead control panel replacement and programming.
I wonder, how could a simple NTC/sensor can go bad quite fast ?
Communication glitch like I once had ? Or indeed the NTC/sensor went bad ?
How is yours Cali, is it still showing wrong temperature values too ?
About OP... I don't think the dealer Xentry has issue reading OCP 70B1 sensor... so what else can it be: footwell GND post.
Despite what we read about wonderful LIN, I think it's very sensitive to poor GND reference. Its not differential like CAN-H/L. When the GND is noisy the link is broken. Default value is substituted.
A new module will appear to fix that by adapting to what the current GND level.
I think if the NTC/sensor is disconnected the default is not -10C, but more like -40C or so as I recalled.
https://w220.wiki/Overhead_Control_Panel_(OCP)_(N70)
