Sponsored by: CARiD
Excessive wear on the outer front right edge tyre
Old Jul 1, 2025 | 03:44 PM
Sambugnet's Avatar
W212
Hi dear forum members,
My problem: Excessive wear on the outer front right edge tyre, The car: W212 2014, 4matic, Airmatic. Context: Tyres Pirelli P-Zero MO, 245-40-18, Last March, I performed a complete front-end suspesion overhaul, including front Airmatic struts, lower and upper arms, control arms...the whole set! Subsequently a specialized workshop did a front axle alignment (It wasn't quite right Job, but more or less within tolerance, nothing seems particularly serious). And the car....wow, it goes perfectly straight, it doesn't vibrate, it's a very pleasant drive! But the problem I describe in the title has arisen in the last months, there is an Excessive wear on the outer front right edge tyre,
I attach a couple of photos and I'd like some feedback. Is this due to misalignment? How is it possible that the problem is only affecting that wheel-tyre? Improper alignment, specifically toe and potentially camber, is a primary culprit ?
Thanks in advance
KR
Old Jul 1, 2025 | 04:22 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
this is TOE'ED-IN too much regardless of alignment printout numbers: tires show it... unless of course you turn street corners at full speed on soft-tires - Then it's normal ie. to be expected.
Any physical freeplay left in your front wheels: bearings, tie-rods, ball-joints. (control arms + struts are already new).
Old Jul 7, 2025 | 07:35 AM
Sambugnet's Avatar
W212
Hi CaliBenzDriver, thanks for your help. TOE'ED-IN just one tyre (front right) ? that's what confuses me..........I suspect that it may be camber, is almost neutral...
The camber isn't adjustable, so I need specific bolts. https://www.distri-auto.es/febest/1629-212-kit-592404
I think I'll buy them and see if it fixes the problem.
Old Jul 7, 2025 | 10:17 AM
Mikes62's Avatar
That could be toe or camber. I’d take it to a shop that has the computerized alignment rack, once you find out what the proper specs are.
