Sponsored by: CARiD
Dear Air Suspensinon - I HATE you.....
Old Feb 27, 2026 | 09:46 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
So, pump in one of the cars go bad...take the pump out of another car, put it into the car (AMG) I prefer to drive, order a new pump, put the pump back in the other car...life is good. Then.....
I get another pump, they are cheap. I also decide to put in a new solenoid (Using RMT parts). The solenoid does not stay connected, hoses pop out (I blame RMT). So, the solenoid that was on the car was working perfect so I will put it back on - WRONG. The hoses pop out!
I spend days finding the right brass fittings for the solenoid. No luck - the hoses pop out. I cut off some of the hose to get a nice clean STRAIGHT section...they hold - and now air is leaking from the solenoid body as I screwed up the plastic threads on the body. Teflon tape as a theory, no help.
Now I have the RMT solenoid back on order...and now I need to replace some of the (smaller) tubing under the car - I assume one to each wheel, cant be that hard to run.
My hunt for the connectors was long - who has the MB number for the hose? I know it comes as a roll - but, what is the number? Anyone know?
Old Feb 27, 2026 | 06:47 PM
juststeve's Avatar
2012 E63 Wagon
I think the size is 4mm. came up with the following:
ebay kit
A0003270169 inline connector
2203271045 OEM# tubing Repair size. 1520mm.
Old Feb 28, 2026 | 12:47 PM
SpiderMan713's Avatar
2005 E320 4-Matic Wagon and 2016 E350 4-Matic Wagon
Your friends at RMT sell replacement 4mm OD hose too. Per RMT website, MB Part A 000 327 01 69
Mercedes-Benz E-Class W212 2010-2016 Air Ride Suspension Air Line Hose - 5 Ft. (1.524m) (A0003270169)
Old Feb 28, 2026 | 05:50 PM
I have now tried three tunes from Amazon / eBay...none are identical to what is on the car....BUT....on the stock tube I (for the time being) got the car up and driving by zip tying the solenoid to its bracket due to shortend hoses.
Old Mar 1, 2026 | 01:40 AM
BenzV12's Avatar
W212 FL
I dreamed of owning an E Class with an Airmatic acknowledging its weak points as well .
Sorry to hear those mishaps . We have Technical and Vehicle Assistance Forums as well. You should also be checking it out
Old Mar 6, 2026 | 03:38 PM
RDE38's Avatar
2011 e550
I replaced one of my entire lines with this tubing, (10 feet I think) going from the solenoid to the front right strut. It was a pretty big pain finding good routing and hiding under heat shields/body panels etc. I had been using a coupler under the battery tray for a couple years where the factory line had frayed and it never held completely air-tight. The suspension would sag over a couple of days. But I am finally leak free.
