E220 Estate Rear Air Suspension
The rear air suspension on my 2016 E220 Estate wagon has dropped on both sides. This is not the first time it has happened - in December 2024 I had to replace the compressor - but generally it doesn't give problems. The car has normal spring suspension on the front.
This time the compressor is working just fine (if I link the high power contacts together) but the relay mounted behind the trim in the boot area isn't getting any voltage to energise the relay coil. With the compressor running, I have tested that air is passing through the valve block to the hoses/pipesthat go to the air bags but the suspension isn't rising so I'm a bit confused
I'm damned if I can find the wiring diagram or block functional diagram I used in 2024 to diagnose that problem so wondered if anyone can provide one, or a link to an on-line source?
Any assistance will be much appreciated
EDIT TO ADD: The VIN number is WDD2122012B326212 - it has code 677 for "Avantgarde/Standard Suspension" (whatever that means)
As the power relay for the compressor isn't being activated I am wondering if there is an electrical gremlin at play, hence my desire to have a block schematic and/or a wiring diagram.
If the level sensor is whack then the relay may not be getting signal as the sensor data goes through a bunch of computers and stuff before it energizes the relay.
I've not yet dumped air straight into the bags - I'm waiting for a couple of Schrader valve-to-4mm pipe adaptors to arrive on Wednesday so I can do that. If the bags then take and hold air I can get more adventurous with my fault finding as I'll be able to get the car onto a level surface and put it up on axle stands - it's currently on ramps at the rear. I have no reason to believe that both level sensors failed at exactly the same time - it feels too unlikely - which leads me to suspect there is another single point of failure aside from the valve block (which appears to be functioning correctly). This elusive single point of failure could be something in the electronics or the wiring that's stopping the power relay from being energised. Of course, it is possible (if not probable) that the height sensors have been damaged by the collapse of the suspension and this is adding to the complexity of the issue.
"With the compressor running, I have tested that air is passing through the valve block to the hoses/pipesthat go to the air bags but the suspension isn't rising so I'm a bit confused
"I'm not sure how else to interpret the above statement.
An air leak in the scenario you describe is most probable. In the case of the more anomalous electronics failure (barring any previous human intervention being a potential cause), you'll need the appropriate diagnostic equipment. Speculation diagnostics is not appropriate for a Mercedes Benz.
