E-Class (W213) 2016 - 2023
Key Fob not detected. New batteries
Old Nov 22, 2023 | 12:24 PM
ua549's Avatar
Originally Posted by Egonvdv
every now and then i can no longer use keyless entry
but if i use the buttons on the key, it works perfectly fine,
so it doesn't seem to be the battery, or is it indeed a sign to replace ?
Are you sure that you have not deactivated the key?
You can press the lock button twice to deactivate the key.
Nothing special is needed to activate it again.
As soon as you press another button on the fob, it will jump back to life.
Old Nov 22, 2023 | 12:43 PM
Egonvdv's Avatar
EQE SUV AMG-line 350+
thanks. I know this, but that's not it...
Old Nov 22, 2023 | 01:38 PM
Diesel Benz's Avatar
How would you know you have not accidentally pressed the lock button twice? Not very likely but possible. Perhaps the issue has happened while you have watched after the key. Another one is that you move too smootly, the key does not wake up from sleep. No idea how small movements wake up the key.
