Questions Regarding Parking Sensors
2 Attachment(s)
Hey all,
So I noticed the past few days my parking sensors have been a bit weird. 1. in the upper left corner, it says LIM by the parking sensors (see attached picture) 2. Sometimes when I am backing up or going forward, I will notice the side sensors will not show up sometimes and other times they will all show up. Like in the pictures I will post, notice how it shows the lines for the side sensors that run from the front bumper to the back bumper (not the front and back sections). If this doesn't make sense I can try to photoshop a picture with the area of the sensors I am talking about. Any help would be appreciated |
I have also noticed the LIM in mine too, but I have the surround view camera. I notice it every time I back out of my tight garage in the morning, and I dont really see it any other time.
doesn't the LIM light mean that you have activated speed limiter?
Wondering this myself, and i did not find anything in the manual about it... I see it when I pull into a tight space at work - I don't see it any other time.
It means that the speed limiter is active.
Thanks - what does the speed limited do? (I get the concept, trying to understand generally what conditions trigger it...)
Parking Pilot limits the speed. In addition you can set a speed limit in Distronic.
I understand that the button at the end of the cruise control lever is used to switch between speed limiter and cruise control. Perhaps you have inadvertently pressed it.
So what does that do? Does it just mean that I can't go over a certain speed with the cameras on?
I know that in the past, other markets outside of the US have that LIM switch at the end of their cruise control stock, but we never got that in the US. There is also no chance of switching it on after just starting the car.
Literally, I start the car, put it in reverse, and then see the LIM. The only thing I can think of is that the car thinks I am surrounded by obstacles and is limiting movement of the car for fear I will hit something. I do notice that the brakes are slightly sticky and can hear the computer moderating the brakes |
1 Attachment(s)
In this picture, this is the other thing I had a question about. See how there is nothing on the sides? Why is that.
Originally Posted by makris0000
(Post 7048236)
(Post 7048236)
Im guessing thats probably what it is because after I move a little they start to show the lines for them (and then when I'm close then it'll have the colored sections).
Don't worry, I looked closely at mine and the side sensors do not show upon startup, and start to show after you start moving a bit. It must need time to initialize.
I also noticed if you go over a certain speed, they will not activate. When I was leaving Publix they went off while the camera was still on and then they came back on when I slowed down.
https://cimg5.ibsrv.net/gimg/www.mbw...b2f06dbae.jpeg I noticed the LIM in the same position as the OP mentions while parking very close to a wall. The LIM message disappears what I move away from the obstacle. AMG E53 Coupe with Active Park Assist and Surround View Cameras. I noticed when configuring parking and maneuvering assistance “LIM” is at the front of the car in the display graphic. It is part of the parking assistance feature, just not sure exactly what it means. |
I believe that when "LIM" appears, the system is operating at or beyond the limits of its capability. In this case, it means that parking assistance cannot be provided because the space(s) around the car are too tight for proper operation.
Originally Posted by bytemaster0
(Post 7641995)
I am pretty sure the LIM is the speed limiter. I have tried pushing the throttle further down when I see the lim and nothing happens. The car prevents me from speeding up beyond normal idle speed
Originally Posted by joshg1001
(Post 7642347)
(Post 7641995)
