MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   E-Class (W213) (https://mbworld.org/forums/e-class-w213-208/)
-   -   Retrofitting Coupe/Conv air vents or not? (https://mbworld.org/forums/e-class-w213/672308-retrofitting-coupe-conv-air-vents-not.html)
vic viper 07-04-2017 04:35 PM
I am torn, should I retrofit the coupe air vents or leave them as is?
I really like the sportier look of the coupe vents but then again the standard ones look very proper and classy.
Another pro is that the open/close flap knob is deleted using the coupe vents.
Having a hard time deciding here, what do you guys think?
https://cimg9.ibsrv.net/gimg/www.mbw...9891ae194a.jpg
joshg1001 07-04-2017 05:09 PM
Personally I like the look of the normal sedan ones. If you end up changing it to the coupe ones, does that mean you will replace the wood dash so that you are without the open/close knobs or will you keep them there as well?
vic viper 07-04-2017 05:15 PM
Yes, in that case I will replace the whole panel, also replace the panel and vents behind the armrest box.
grange3 07-04-2017 08:14 PM
Hi Vic Viper,
i think the new coupe air vents look very cool and if you can change the vents in your car to the new look coupe ones it would make the interior of you car sportier and quite unique, if you go all the way with the job like you are saying please take some pics and post on here for all of us to see.
teksurv 07-05-2017 09:59 AM
My take is the coupe vents look great on the coupe/cabrio. For the sedan/wagons, I like the originals better.
vic viper 09-21-2017 12:55 PM
And so it begins..
https://cimg0.ibsrv.net/gimg/www.mbw...96866646e0.jpg
https://cimg4.ibsrv.net/gimg/www.mbw...ec5befe32a.jpg
petee1997 09-21-2017 02:25 PM
Don't reinvent the wheel. Those turbo vents look great on the coupe.
vic viper 09-21-2017 02:33 PM
Yes, but inside of the car, how do you know its a coupe or a sedan? ;)
arnsbrae 09-21-2017 03:12 PM
The turbine vents are great to live with - nice and easy to adjust and point. I also agree they’ll look great in your w213...
ua549 09-21-2017 04:27 PM
It's a coupe if the passengers in the back have bruises on their head. :rolleyes:
petee1997 09-21-2017 06:30 PM
I usually count the number of doors.
ua549 09-21-2017 06:45 PM
Hmmm, that CLS400 you have is called a coupe. 4 doors?
:rolleyes:
petee1997 09-21-2017 06:51 PM
:rolleyes:
Calling the CLS a coupe does not make it a coupe.
vic viper 09-22-2017 12:32 AM
There is also a practical advantage to the swap, in the "knob style" flap adjuster it is sometimes hard to select a flow value of about 50%, the knob tends to go back to fully open.
Mbracer26 09-23-2017 02:05 AM
So you are saying you can close off each vent off instead two at a time? If so this would solve the annoying slow airflow out of the center vents. They don't even hit your face to cool you off.
vic viper 09-23-2017 02:55 AM
Yesn, they are individually adjustable.
vic viper 09-25-2017 07:32 AM
Parts keep coming in
https://cimg2.ibsrv.net/gimg/www.mbw...36a45186c8.jpg
Mbracer26 09-25-2017 05:33 PM
Originally Posted by vic viper (Post 7271313)
Can you only change the vents and leave the wood and adjuster lever in place?
vic viper 09-26-2017 12:23 AM
Dont think so as they are different sizes, but Ill look into that while swapping.
mcflo 07-31-2018 04:56 AM
Hi Vic,
has this been taken further?
Did you retrofit the coupe air vents?
Looking forward to do the same.
Do you have a hint on how to change the outer air vents near the windows?
Thank you
Best, Florian
vic viper 07-31-2018 08:46 AM
Originally Posted by mcflo (Post 7516634)
Hi Vic,
Thank you
Best, Florian
https://mbworld.org/forums/e-class-w...air-vents.html
© 2019 MH Sub I, LLC dba Internet Brands
