anyone retro fit the 12.3-inch digital instrument cluster?
the only option id like to have is the wide screen dash. has anyone attempted to retro fit?
secondly, has anyone retro fit the LED distribution bar behind the instrument cluster that is lacking in cars without the digital instrument cluster? Thanks! |
Originally Posted by 618
(Post 7297137)
I am going to do this as well appears to be plug and play. Vic Viper we need help. |
The software will be quite different and it may be unobtainable.
It will only work if you have the COMAND system, if you have the analog display and the small infotainment screen it wont work.
You will also need access to Xentry diagnosis to SCN code the widescreen display as well as adjusting the odometer and service data. |
Originally Posted by vic viper
(Post 7299489)
Bump
It is possible and not complicated
Originally Posted by hime100
(Post 7646375)
Originally Posted by EMEIVI
(Post 7299321)
https://www.youtube.com/watch?v=dfbQpRo_8_M
I am going to do this as well appears to be plug and play. Vic Viper we need help. https://www.youtube.com/results?sear...reen+retrofit+ |
There are warranty considerations with the parts and related systems changed. The all digital display is truly an upgrade, but it may be best to wait until after the warranty expires, if applicable.
Originally Posted by teksurv
(Post 7647397)
Has anyone done this?? I'm looking to buy an E but most people haven't spec'd this, and the ones that do have things I don't want, so would be interested in doing this.
I woul like to ask if anyone with audio 20 retrofit the widescreen in this unit Audio 20 usb NGT5 with garmin map pilot code :
522 AUDIO 20 RADIO NAVIGATION CAPABLE NTG5 355 PREINSTALLATION FOR NAVIGATION RETROFITTING |
Help
I have been looking for the past 2 months to have someone retrofit the fully digital instrument cluster into my 2017 E300 W213 i am located in the US specifically in New York... i have went to dealers and aftermarket places and everyone is scared to do it ... if anybody knows who would be willing please let me know ASAP
In Canada we only had the all digital dash. Weird.
Originally Posted by rbrylaw
(Post 7646768)
Perhaps not. But securing an OEM digital dash isn't inexpensive and it requires more than just plugging it in. It has to be properly programmed.
Originally Posted by YANG LI
(Post 8163642)
The Problem I got is that when I change to the wide screen cluster. I'm missing 2 wire to connect to my new wide screen cluster. anyway to solve it ?
(Post 8163642)
What wires are you missing, maybe your car didn’t come with the option for that. One is the heads up display. The new display will also require coding and changing your miles to be what you had on the old one. |
