Eco On-Off and what I did about it
I hate having to press the button to bypass Eco-Off each time I start the car, so I bought a device sold by Vladimir on Ebay for less than $150. It takes less than a minute to plug in and out of the OBD port next to the hood lever under the steering column. This leaves the Eco-Off the way you want it. It works on a 2018 E400 and there is nothing to install and is reversible in case you want to reverse it. BTW, Vladimir is a member of this forum.
What is the main reason that you dislike about the eco system? just curious.
You mean besides the fact that it is incarnate evil? I bought the EcoOff 205 from Midcities Engineering and I am thrilled that now I can decide whenever I want auto start stop. |
Other the AC turning off I see no reason what so ever to dislike this function.
Originally Posted by vic viper
(Post 7419620)
I dislike it due to the extra wear and tear of 1000,s of extra starts . |
Originally Posted by swatty
(Post 7419643)
Originally Posted by jhpmbusa
(Post 7419514)
(Post 7419514)
Originally Posted by vladimir.cdi
(Post 7419704)
most dangerous situation with ECO-start-stop is when you turning left at high trafic and exactly same time when you are ready to accelerate to pass the intersection, ECO decide that is a RIGHT TIME TO STOP engine, then it takes 0.7sec to start again. really dangerous
Eco start/stop why do I hate thee.
Anyone that thinks it's okay for an engine to start and stop a million times a year is out to lunch. I don't care if Mercedes says that it's built to do that, it's horrible for your car, and all engine components.. and unless you drive like an old man or are just a ****y driver it's pretty unsafe as well.
In fact one of the reasons why people enjoy tuning these cars so much is for the faster throttle response... You also have to keep in mind that most people on this forum can't even do the most basic things like change a flat tire so it's not really the best place to tell people about modifications. |
Originally Posted by Ariesfamous
(Post 7419743)
In fact one of the reasons why people enjoy tuning these cars so much is for the faster throttle response... You also have to keep in mind that most people on this forum can't even do the most basic things like change a flat tire so it's not really the best place to tell people about modifications. Over 2700 start and stops a day, you must use your car pretty extensively?Also with some basic engine know how you would know that a warm engine using quality 229.5 grade oils wont take harm because of the start stop function. If they were cold starts it would be a totally diiferent deal, but as most of you know, start/stop wont activate until all requirements are met including an engine at working temp. |
@Ariesfamous
I doubt that and engine will restart twice a minute as you imply. Engine components are designed for specific duty cycles. MB's new I-6 engine will start and stop much more frequently without the driver feeling the change over from gas to electric. The issue with the current setup is the lack of electric motors with instantaneous response. Finally, you have no idea of what the capabilities of the members on this board are so keep your opinions about member's skills to yourself. |
I have no idea about the wear and tear aspect, but this is my third Mercedes with this Eco Start-Stop function. I despise it. Two M276 NA engines and now a M276 Biturbo engine, none are smooth on restart. The car shakes a bit. The fraction of a second delay to accelerate is not appreciated. The lack of A/C is not appreciated. So while I understand why Mercedes and others use this, I'm happy to disable it.
Lol. No wobder these forums are dead.
(Post 7419704)
(Post 7419743)
You also have to keep in mind that most people on this forum can't even do the most basic things like change a flat tire so it's not really the best place to tell people about modifications. 704set |
Originally Posted by ua549
(Post 7419771)
@Ariesfamous
(Post 7419895)
Lololololololololol. I'll state my opinion as I choose.
(Post 7419895)
ECO Start/stop is disliked by as many people as run flat tires. This isn't a feature that MB created because people wanted it; these are simply tools to meet environmental/fuel economy mandates. Still, the engines work work just fine. Dimitri's module is a perfect solution, just like Mid City, Brabus and others... I never have to disable mine because I always drive Sport Plus mode. Problem solved ;) |
You still have to make that selection every time you start the car don't you? My car always starts in comfort mode and I have to switch modes manually. That takes the same effort as turning off Eco start/stop. I wish MB would make those settings sticky.
I noticed it's the same few guys that have to chime in on every single post,you guys should try going outside there's a whole world out there.
Enjoy your day. I won't get into what I know about tech as my penis is not that little that I need to fight on some forum. |
(Post 7420128)
(Post 7420073)
MB used have some sticky settings but eliminated them unfortunately... Sport or Sport plus mode (depending on model) will turn ECO off, otherwise we would have 2 clicks. Now at least there is one worthwhile selection ;) |
(Post 7419656)
It won't, the starter and other related functions are designed to work this way.
