w213 e200 Subwoofer not working
Hi All.,
I am new to the forum although i keep on reading very interesting posts from the members :) I just bought a w213 eclass 2017. It is installed with the standard basic audio system which has one subwoofer installed near the foot of driver side. I can hear no bass in the system was dissappointing, but the i figured the subwoofer is not working. If i touch it i cannot feel any vibration nor the speaker seems to move at all. I already checked the fuse box. All seems to be in order. Is there some setting i need to check. Any help would be much appreciated. Thanks a lot! |
Its wired between the + of one side and the - of the other side's front speakers. So if your other front speakers are working it should. Unless it came unplugged, so just check the plug on the speaker
Richard |
Hi
well i checked the plug is inserted properly. So no loose wires.Its a new car so i doubt the subwoofer speaker is broken. And yes all other speakers are working as well. 4 in front doors + 2 back doors. Seems to be a Very strange problem.. |
Originally Posted by eclassw213
(Post 7475163)
Hi
:D. Yes ofcourse i did check that. All the bass seems to be adding to the door mid range speakers.
Hello! I don't mean to hijack your thread, but were you able to resolve this? Also, can you/someone suggest where I can find details of the speakers in a standard Audio 20 (NTG 5.5, W213) (impedance, power, size, etc.)?
It has front bass, its integrated in the firewall. Standard audio is very bad so might just be that.
Woofer problem
(Post 7475647)
Did you solve the problem with your woofer? I have same problem. |
If the car Is left hand driven, the sub is at the passenger side firewall.
There is a speaker over the drivers feet that is visible, but I'm quite sure that one are only used for the beeps and stuff. I thought that was the woofer to first. But in my left hand driven car, the woofer was behind the carpet at the passenger sides firewall. I have had some custom sound system installed in my car which I plan to write a thread about. Replaced woofer, door speakers, installed audison prima dsp/amp and 2x8" woofer in trunk (estate w213). Work done by shop though so can't give much instructions of how it was done. But I had to do some research of suitable speakers and woofer and the placement for these myself. Sound is really really good now! |
Originally Posted by Faniskogen
(Post 7844733)
There is a speaker over the drivers feet that is visible, but I'm quite sure that one are only used for the beeps and stuff. I thought that was the woofer to first. But in my left hand driven car, the woofer was behind the carpet at the passenger sides firewall. I have had some custom sound system installed in my car which I plan to write a thread about. Replaced woofer, door speakers, installed audison prima dsp/amp and 2x8" woofer in trunk (estate w213). Work done by shop though so can't give much instructions of how it was done. But I had to do some research of suitable speakers and woofer and the placement for these myself. Sound is really really good now! Did you do the upgrade? I'm in Stockholm too and want to do this upgrade as well as a widescreen retrofit. |
