E-Class (W213) 2016 - 2023
Will the iPhone XS Plus fit in the wireless charging area?
Old 09-15-2018, 04:53 PM
jhpmbusa's Avatar
2021 M550i
just sat in a new 2019 c300 coupe today, they have made the charging are bigger in order to accommodate plus size phones...
Old 09-16-2018, 09:23 PM
Whitney Sorrell's Avatar
BMW 740i
Sackboy will an XS Max fit on the Pad and charge? The concierge said he thinks it will but without a case. I’ve always been a case guy like RBRY but maybe I’ll give The AppleCare strategy a roll. Have an XS max on order for next week too. My 6 Plus -yes my phone is that old- still looks brand new thanks to the otter box.
Old 09-16-2018, 09:28 PM
rbrylaw's Avatar
2019 E450 4Matic & 2018 E400 4Matic
He had posted earlier that the iPhone Xs Max will hot lay flat on the charting pad. My iPhone X in a case, just barely fits, so I know the Max won't for sure. And he took a cardboard cutout with him to test it in a E and it did not fit the pad. The first of two cases I ordered for my Max arrived yesterday and the 2nd one arrives tomorrow. I'm just not personally concerned about the phone charging by the pad. The only time I have mine in that area is if connected to use Apple CarPlay. When plugged for CarPlay it will be charging anyway.
Old 09-16-2018, 10:25 PM
sackboydad's Avatar
2019 E450 Cabriolet, 2020 GLS450
FWIW my salesman told me MB upped the size of the charging pad on the 2019’s. When I took my cardboard cutout, it was looking at a 2018.
I have the the car..... Friday I’ll have the XS MAX and will report back if it works or not.
The following 2 users liked this post by sackboydad:
AZEZ (09-17-2018), rbrylaw (09-16-2018)
Old 09-21-2018, 10:46 PM
sackboydad's Avatar
Got my XS Max today and tried it in my 2019 E450 Cabriolet.... the phone fits PERFECTLY and charges just fine.
However if if you have a cable connected for CarPlay and use the charging bay as storage, the phone will stick up a little because of the connected cable.
Old 09-22-2018, 07:54 AM
Cambridgehank's Avatar
E400
How did you get the phone to charge? When I put my iPhone 8plus into that location either Apple Pay shows up or nothing at all.
Old 09-22-2018, 08:35 AM
  #32
sackboydad's Avatar
you need to go to the connectivity menu in COMAND and turn off NFC, then it will stop trying to connect to Apple Pay. Unfortunately, I think this only works on 2018 and later (maybe 2019).
But it it should charge even if the NFC triggers. Just tried it and mine still charges even when asking for Apple Pay
Old 09-22-2018, 09:02 AM
  #33
rbrylaw's Avatar
Turn off NFC in your System Settings. NFC pairing isn't anything you really need on your car for iPhone. Before I figured out I could turn off NFC, my iPhone X still charged however.
Old 09-22-2018, 09:04 AM
  #34
rbrylaw's Avatar
Will someone be out driving ALL weekend with the top down?? Huh? Will they? Welcome home.
They must have made the charging mat area bigger in the 2019. I got my XS Max yesterday and it won't fit the mat in my 2018.
Old 09-22-2018, 09:18 AM
  #35
sackboydad's Avatar
according to my SA, yes they did make it an inch or so longer to accommodate bigger phones
Old 09-22-2018, 09:29 AM
  #36
rbrylaw's Avatar
That's good to know. Thanks. It's possible I may be taking the E450 I had originally ordered, which will arrive in late October. If we do that, my partner will take my E400 and we'll trade the E300 in. It all depends on the hit we'll take, but the E450 I ordered has EVERYTHING I originally wanted.
Old 09-23-2018, 06:27 AM
  #37
sackboydad's Avatar
After reporting that the XS fits perfectly in a 2019 E450 Cab, want to make sure it’s known I do not use a case on my phone. So be careful as I’ve not tried it with the small amount of size that a case will add.
Old 09-23-2018, 09:34 AM
  #38
rbrylaw's Avatar
Still larger is nice. I kept my (now departed) iPhone X in a case and it barely fit the E400. iPhone Xs Max does not fit the E400 at all.
Old 09-23-2018, 11:44 AM
  #39
raja777m's Avatar
2014 E350 4M Diamond Silver
It's actually called iPhone XS Max and NO, it will not lay flat in the charging mat. I currently have iPhone X in a slim case and it barely fits, but it does fit. I can assure you the XS Max, will not. When I plug it in to use Apple CarPlay, it doesn't fit at all. I'm still getting the XS Max regardless. I'm not letting the built in charging mat determine the size phone I can use.
I got a loaner (e300 2018) the other day and my iPhone X with red apple leather case fit it in well. But yeah, the XsMax might not properly.
Also, note 9 is bigger than XsMax right, I believe Benz would design keeping that phone in mind too.
Old 09-23-2018, 01:40 PM
  #40
CaptainE's Avatar
2019 E450 sedan
I wonder if my Galaxy S8 will fit. I don’t follow the crowd with all this apple stuff.
Old 09-23-2018, 01:43 PM
  #41
ua549's Avatar
My S9 fits with room to spare.
Old 09-23-2018, 04:15 PM
  #42
Lanzz's Avatar
2021 GLE350, 2021 E350 / Used to drive: 2019 E300, 2020 GLE350, 2019 E450 Wagon(s), 2017 E300 Sedan
XS Max does not lay flat on E300 charging mat, but it does charge without an issue.
Phone is in the slim Otterbox, and the end closest to me sticks up a bit, but it is a workable setup.
Old 10-30-2018, 02:35 PM
  #43
nycebo's Avatar
Mercedes Benz e450 Wagon / Porsche 911 Cabriolet
I hate cases and don’t use them. Accidents are what AppleCare is for 😬
I'm slowly coming around to this line of thinking.
Old 10-30-2018, 02:38 PM
  #44
nycebo's Avatar
Originally Posted by knoppe01
FWIW - I haqve a Samsung Galaxy S9+ While it doesn't lay flat in the charging area it charges without issue
Do you use a case? How do you insert it into the charging pad? Cable jacks facing inwards or outwards? Face up or down?
I had trouble getting mine to charge last night...it was intermittent and generally disabled itself.
Old 10-30-2018, 08:29 PM
  #45
rbrylaw's Avatar
Just got my E450 Sedan today and am delighted to say they made the charging mat larger. My iPhone Xs Max WITH a case fits just fine on the charging mat! Woo Hoo!
lensjack (10-30-2018)
Old 10-31-2018, 10:52 AM
  #46
nycebo's Avatar
An update in the Samsung Galaxy S9+...
If the phone is inserted into the charging pad face up AND with the charging and headphone Jack's facing inwards, then it charges!
Old 01-10-2019, 09:42 AM
  #47
nycebo's Avatar
One more update:
On my S9+, sometimes the charging stops. For a long while, I couldn't figure out why. Last night, I spent some time investigating the charging pad area. It turns out that the dimensions are not consistent. If I place the phone towards the left of the pad, it doesn't really sit flush and sits slightly above the pad. It still gets a charge but it sometimes messages me that it isn't able to. However, if I place the phone towards the rightmost part of the pad, it "slots" into the area much better and maintains a charge consistently.
So, with larger phones, don't just drop them in there. Instead, ensure that you are seating them all the way to the right and it should offer better results. Cheers.
Old 01-10-2019, 10:38 AM
  #48
stephos's Avatar
MY19 E450 4MATIC Coupé
I'll give this a go as my phone (Google Pixel 3 XL) doesn't sit flat either. It seems to be a bit too tall but I haven't tried moving it from left to right in the tray to see if it makes a difference.
Old 12-12-2022, 09:14 PM
  #49
Goose254's Avatar
2019 Mercedes E 300
Has anyone had any luck finding a replacement charger that fits the larger phones like an iPhone Pro Max? I’m not that worried about the wireless charging but it would be nice to have a space that the phone fits.
Old 12-13-2022, 11:12 AM
  #50
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
Is it the width or the length that's the problem? If the latter, then might it be possible to cut/shave off the lip of the charging area, the lip that appears to help keep the phone in place?
Quick Reply: Will the iPhone XS Plus fit in the wireless charging area?
