Steering Wheel Up/Down Adjustment Not Working
A few weeks ago my steering wheel stopped going up and down when trying to adjust it. I can still move it in and out, but it stopped going up and down. Has this happened to anyone else yet?
I plan on taking it to Mercedes when it comes time to do Service B in a few weeks, but I'm just curious if this happened to anyone, what they dealer said was the cause, and if they had a problem when bringing it to the dealer to get it fixed under warranty. Thanks. |
This is a well known issue that plagues several MB cars.
As it's covered by warranty, just get it replaced. If you want to try, use the knob to force it to the highest position (yes, I realize there will not be any apparent movement due to the issue you presented), then take your arm and bang down really hard on the steering wheel. Chances are it'll get it working again... |
You might get it working, but if not replaced it will fail again.
I tried multiple times to get it working but part of me feels like I will break it if I go too hard. When I schedule my next service I’m going to have them replace the up/down motor. Thanks all. |
Replacing the motor will require removal of the entire column, there is a repair kit available for this, make sure they order it before your appointment.
This happened to me, but was intermittent. The first two times I took it to the dealer, they told me it just needed to be lubricated and sent me on my way. I finally took a video of the failure and asked that they replace the appropriate parts. That seems to have solved it.
Not sure if you have the easy entry/exit feature on, but in the older models, this use to break all the time. Seems that people would put their weight on the steering wheel while it was moving and it would tend to break some piece in the steering column. It could also be something else, but you might want to be careful in the future in case it breaks again out of warranty.
Originally Posted by cetialpha5
(Post 7621190)
This is caused by a production error, it will not fail because of normal use or putting external load on the column. Once replaced it will work. |
Originally Posted by vic viper
(Post 7622313)
My W204 goes in to the dealer tomorrow for the same thing (under warranty). Will see what they do with this. I will most likely be disabling the exit up/down feature once I get it back to save the motor.
Originally Posted by 25th Car
(Post 7676667)
I brought mine in this past weekend for Service B and do do warranty work and among other things, the steering wheel. They told me it needed a software update. Who knows how long it will last for but at least it’s covered under warranty. |
No software update nor cycling the other servos will solve this, have it fixed before your warranty runs out.
mine has been stuck in the up position for the past month. Haven't had time to take it in. will be the 16th time going in for service.
Originally Posted by Mbracer26
(Post 7680929)
Mine hasn't stopped working, although it makes a strange sound the entire time it moves upward or downward automatically. I'll record it and take it in for service.
Mine is a lease so once the lease is up it’s going back. Luckily I have full warranty for the duration of the lease. Mine has only done it once since getting the last service and the update a few months ago. What I did to fix it was I pressed the thing to make the steering wheel go down while pulling down on the steering wheel and it came down again. Hopefully it’ll be good for another year and a half.
Took mine in to the dealer for this and was told the repair required a part to be lubricated. It worked....for one week and is stuck again.
My guy who knocked it back into action said that too. I now have some screen shots of other posts talking about repairing this problem. I'll show him the work order
Originally Posted by makris0000
(Post 7619161)
It worked!
I pushed down hard on wheel while simultaneously pushing down on the tilt lever. Worked like a charm. Whatever that means:)
QUOTE=superangrypenguin;7619495]This is a well known issue that plagues several MB cars. As it's covered by warranty, just get it replaced. If you want to try, use the knob to force it to the highest position (yes, I realize there will not be any apparent movement due to the issue you presented), then take your arm and bang down really hard on the steering wheel. Chances are it'll get it working again...[/QUOTE] |
Permanent Fix
Does anyone know the part number or if it could be a DIY to fix the steering column?
I could not find a video. Appreciate the help. |
Why not just take it in. I got mine fixed under the warranty
Out of warranty and the dealer by me is horrible. Even MB USA acknowledges it, it is privately owned and they cannot do anything about it. This dealer is literally the worst thing about owning a MB. I seriously doubt I will buy another one bc of them. Great car otherwise. The same group also owns the BMW dealership, so I am not sure what I will do next.
Go to another MB dealer. There are 14 in NJ.
