Ok so here’s a weird exhaust issue with my E450 wagon.
2022 GLE 450 (Black on Black)
On our CLS450 both tail pipe reflect black exhaust. Also, in many other cars when equipped with quad tail pipes, only two actually reflect the black exhaust. And in other vehicles like BMW's only one actually works. bottom line, the manufacturers installed them (dual and quad) for appearance.
Mercedes Benz e450 Wagon / Porsche 911 Cabriolet
Mine is smooth is glass but I'm not only not running Goodyear RFT (mediocre), or Michelin RFT (better), but Pirelli regular tires. They have been good. However, I'll likely go for the Michelin Pilot Sport A/S 3 regular tires next time round; the reviews are just too compelling.
As to the wagon ride, I don't have the specs, but perhaps it's heavier than your cab. Also, it has the rear air suspension to level the trunk.
I have the Goodyear RFT on the CLS 450 and keep the air pressure at around 33-34lbs as recommend and i have no issues with the ride quality. When i received the car new from the dealer, the tires were set at 38!. This cause the ride to be a bit bumpy but i did not mind. You get perhaps better mileage. Just follow the Tire pressure guide in your gas cover cap and you should be ok.
2018 S560 and 2019 E450 Wagon.
I think there has been something flukey on my wagon since day 1. The vibration from the rear makes kinda a pulsating sound as I’m driving along. I’ll have them force balance the rear wheels and check them for roundness. You never know one of the rear wheels might have been out of round from day 1. If that does not do it I’ll change the tires out. Maybe the same tires I have on the cabriolet as I’m more than happy with the ride in that car. They are Michelin Primacy 3 245 40 r19 inch. Can’t find anything on them that says they are run flats but I assume they must be as no jack or inflator in the Cabriolet.
In a word, yes.
nycebo (03-14-2019)
@2012 merc amg I definitely recommend a wheel balance on all wheels before doing anything. Hopefully the problem is thus easily resolved.
@ua549 thanks big time for the real world opinion. I hadn't considered longevity. Good to know.
#32
This. If you start on Eco or Comfort, then go to Sport (if already driving) or Sport + on a cold start to get the second exhaust to open up. More efficient when considering throttle, exhaust, back-pressure, etc.
#33
My e200 sedan has exhaust going out of both, visible when cold. I notice this when the reversing camera is on and it might be that the engine is warmed up. I rarely put it out of comfort mode also.
