E-Class (W213) 2016 - 2023
How do you determine best Tire Size/Wheel Width and Offest?
Old 03-04-2019, 01:58 PM
5Hundred's Avatar
2014 C63 P31 Coupe; 2022 R8 Performance RWD; 2018 Stelvio Quadrifoglio
W 213 E300 - Sedan
Sport Package
Premium 3
The car has a good amount of under-steer compared to the W212 I am used to driving.
I am looking at buying a set of staggered wheels and tires but other than bolt pattern, I don't know where to start.
I dont drive like a maniac but I just like having smooth and consistent control. Traction control goes off all the time on wet road conditions.
Currently.
245/35/18 (all around)
Stock performance tires
https://www.ebay.com/itm/18-Genuine-...Qf8e:rk:9:pf:0
Old 03-04-2019, 03:01 PM
ygmn's Avatar
2015 E400 Sedan
you might be able to put 265/30/18 on rear with existing wheels.
adds bit over 3/4" in width which would push inside tire surface 3/8" - see if you have enough room...
Old 03-04-2019, 03:41 PM
threeMBs's Avatar
Only MBs - the best or nothing
245/35-18 is way incorrect size for W213 (should be 245/45-18). 265/30-18 is even more so (btw, incorrect for W212 as well). Additionally fyi 265/30-18 can never be fitted on (W213 stock) 8" wide rim (need 9" wide minimum).
Old 03-04-2019, 05:01 PM
ygmn's Avatar
2015 E400 Sedan
on my w212 E400 sedan
front = 245/40r18
Rear = 265/35r18
Old 03-04-2019, 06:08 PM
threeMBs's Avatar
Correct. However, what does W212 have to do with W213 regarding this thread?
I do not even understand OP's question. For starters, there's no way 245/35-18 can be on his W213 (its a massive 2" less diameter than stock). Maybe there's a typo, but there're too many variable to guess.
Old 03-04-2019, 08:30 PM
Cao Black's Avatar
2015 ML350+2021 E350
Play around to your heart's content.
https://www.willtheyfit.com/
Old 03-04-2019, 11:41 PM
suby01's Avatar
2024 AMG GLE 53
I’m also in the process of wheel shopping. It’s a little nerve recking with the custom wheels that need to be built to your cars specs. Its no longer a afternoon trip to wheel store and getting a set of nice wheels mounted that same day.
I’m hoping we get some actual useful answers in this thread.
Old 03-05-2019, 03:06 AM
vic viper's Avatar
S213
Use your stock wheels as a reference point then use www.willtheyfit.com
As long as you aren't lowering there won't be issues.
Old 03-05-2019, 08:15 AM
threeMBs's Avatar
I found www.wheel-size.com to provide the most info:
https://www.wheel-size.com/calc/?whe...cl=30mm&sr=0mm
Quick Reply: How do you determine best Tire Size/Wheel Width and Offest?
