More defects than I would have thought....
Now I’m on my fourth defect on my E450 cab...
1. Aux battery had a fault that lit the warning light. Apparently fixed with software? 2. Right passenger window not secured all the way and visibly moved when touched. Fixed. 3. A moaning/whining noise whenever the ABC airbags are filling. 4. Now, the passenger Air Scarf has failed. You turn it on, the lights light up. A few seconds later, the fan comes on and about 3 seconds after that, the fan cuts off and the lights turn off. Is it me or is number of defects higher than one would expect? I know they’ll give me a loaner, but it won’t be a Cab 😩 |
To me, One Fault is too many issues for the price of purchasing an MB.
Originally Posted by ygmn
(Post 7701185)
Originally Posted by sackboydad
(Post 7701024)
Originally Posted by jl199986
(Post 7701348)
Did they resolve this? I think I hear this in my wagon with the rear air leveling. Faint, almost like a power steering moan. Usually shortly after starting up, like at the end of my driveway, or end of the street. Still, unacceptable for a MB. Did they correct it at all?
I wonder how much they’re supposed to inflate. I’ll be sitting in C mode and I’ll hear the noise at a stop light. Why is a strut filling when I hadn’t lowered then raised the car? Since the car will likely be in the stirrups I’ll ask them to do whatever test to see if the struts are holding their air properly |
My wagon just has the auto leveling in the rear. So its not controlled by the operator. Do you get the same sound when you raise the car?
I'm sorry to see you've had these issues. The only thing that was an issue on my car was the driver door window came with a chip in the glass and it took a month for them to get a replacement window from Germany. It did take a month for them to get me connected to Me Connect. Our E400 has had zero issues. Hopefully, this will be the end of issues for you.
