Steering Wheel Change?
W213 Night Edition 220d. (ML250 SLK350AMG)
Hi
Has anyone retrofitted their W213 with the "original" steering wheel to the new one? If so, are you happy with it?
Is it possible?
M
Is it possible?
M
that is more than possible
the only thing that the new steering wheel have cruise control switchers on it
And the old steering wheel doesn't and it controls from the under wheel module
So if you are planning to install new steering wheel you need the wheel itself plus new MRM module (that is under the steering wheel with gearbox, wipers and steering wheel control and heating switchers but w\o cruise control) plus coding.
King•24 (01-29-2022)
Marc Kaplan (04-03-2019)
For heated steering wheel you will also require the small arm on the steering column. That may be a problem if you have to change the column.
This modules come with different options, with or without heating switcher also
Here is E coupe MRM module, Just for example what im talking about
It might be heated on pure amg cars, but a E220d for example looses the sport steering wheel, if you choose heating. This is in the Norwegian online car configuration.
All other might have it
Here is my post about it
https://mbworld.org/forums/e-class-c...ml#post7638195
2022 Mercedes EQS 580
I'm looking for how you do this without coding because coding creates complexity. I found this module. It I wonder if there is something similar for w213
https://carsystems.com.ua/mb-product...eel-adapter-en
My workshop that installed the steering wheel for me, they also made lots of pre facelifted w213s 2016-2017 without that module. Just mrm module, new steering wheel and coding.
You don’t need this adapter for w213 retrofit
E63S.Muc (05-30-2019)
1 Post
2008 C 63 AMG (palladium Silver); 2018 E400 4matic Coupe (Pearl White)
Mine is facelifted. 2019. So no coding for me needed.
Best Regards,
M. Alshamsi
Hey @FedM can you tell what workshop that is? You are saying that a PreFacelift W213 can be retrofitted to the new wheel with MRM and working Cruise Control on the wheel?
Im based in Germany and no one here can do it.
Lots of cars here in Moscow had been retrofitted already by different workshops
So the workshop name won't tell you much, sorry about that
E220D W213 (S213) Estate, 4Matic, Airmatic, 23P full package
Do you know a part number for this?
I want to retrofit my car (e220d 4matic W213, 2017/06), but doing it a right way...
Did not find it online...
thank you.
Just got my new AMG wheel, with the oled gadget.
So, now I gonna need the correct MRM module (2018 facelift e220d, w213)
I don't need heating.
Could antibody help to find the correct part number?
Thanks.
PS I doubt the oled screens will work for you. And do you have Distronic option in you car? What steering wheel do you have right now?
info@mbcomand.ru
You can also reach them in Instagram #Mbcomand
