MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   E-Class (W213) (https://mbworld.org/forums/e-class-w213-208/)
-   -   Driver's side window won't stay closed (keeps coming back down) (https://mbworld.org/forums/e-class-w213/761615-drivers-side-window-wont-stay-closed-keeps-coming-back-down.html)
Axel Notrose Nov 8, 2019 11:46 AM
Over the last 2 days, my driver's side window will no longer stay up/closed. Every time I go to the top, it thinks something is blocking it and comes back down about 5 inches. I therefore have to close it 1/4 inch at time hoping I don't go too far and have it drop 5 inches again and try again.
Is this common? There's no obvious blockage in the window frame that the window slides into. It appears to slide properly into its frame but then decides "nope, I'm not happy, I'm backing out".
Any thoughts on how to address this?
whoover Nov 8, 2019 12:12 PM
Try resetting it.
All doors closed, key in #1 or #2.
Pull up window switch (only first position, not auto up).
When window reaches top continue to hold switch for 10 seconds.
If it drops when you let go, immediately repeat and hold 10 seconds.
Try a few times.
Axel Notrose Nov 8, 2019 01:09 PM
Originally Posted by whoover (Post 7897749)
Try resetting it.
Try a few times.
The window drops back down the second it reaches the top, even when I hold the window switch in the manual up position. So this won't work. Know what I mean?
whoover Nov 8, 2019 01:22 PM
Try resetting lower position first. Same procedure. Hold for 10 seconds after you lower from the high-as-it-will-stay position. Then reset top. If it still fails, something is not working right,
Axel Notrose Nov 8, 2019 06:16 PM
Unfortinately, that didn't work either. Same problem. Any thoughts on what could cause the window to think it's encountering a blockage?
konigstiger Nov 9, 2019 08:39 AM
Have someone check do quick test using Xentry (MB diagnostics) ultimately may be as simple as re-normalizing power window system, or door control unit(s) need software update.
pasaden Dec 18, 2022 07:25 AM
The only fix that worked for me
I tried everything to reset it and nothing worked.
The only solution that actually fixed my problem is explained here
Mashup001 Apr 19, 2024 10:24 AM
Try resetting it.
Try a few times.
Brilliant, as i recently had a new battery put in (having been galavanting in the Philippines for 6 months), and after numerous attempts to get the drivers back passenger window to fully close, when locking the doors, this worked!! I kept pulling up the switch to its second position and not the FIRST position :hammer:. But thank you for this fix, really appreciated.
E220CDi Coupe 2012, Panoramic roof, alpaca leather, satnav, heated/ massage seats, mileage 66,340 miles.
© 2026 MH Sub I, LLC dba Internet Brands
