E-Class (W213) 2016 - 2023
Battery tender hardwire locations
Old May 3, 2020 | 08:50 PM
ShadyJC's Avatar
2018 E400C4
Question for everyone who has a battery tender on their vehicle - how do you have it attached? Do you pop the hood and hook it up via the alligator clips directly to the battery posts every time? Or has anyone hard-wired it with a connector somewhere other than the engine bay? For logistical reasons it's a little hard for me to get under the hood when the vehicle is parked in my garage. In a previous vehicle (Jaguar XKR) I put a CTEK Comfort Panel on a side wall in the trunk which worked great - I'd like to replicate or approximate that setup if I can.
All ideas welcome! Thanks!
Old May 7, 2020 | 08:36 PM
robert c's Avatar
ES350 E300 GLE350 GMC3500 Duramax
Interesting dilemma. If you could use a fuse tap on a live circuit and connect wiring then mount the tender out of sight I suppose would work well but I really believe best to use the clips as temporary rather than permanent somewhere. I use several battery tenders on show cars but simply unclip when needed to load the car for an event
Robert
Old May 8, 2020 | 07:34 AM
JDPEClassUK's Avatar
E Class Estate S213
Not thought about hard wiring. But I parked nose first to garage and have CTEK inside and run connections to battery under bonnet on latch
Old May 10, 2020 | 12:48 AM
ShadyJC's Avatar
2018 E400C4
In your setup do you have to pop the bonnet in order to plug it in? Any chance for a picture?
Old May 10, 2020 | 06:15 PM
E Class Estate S213
yes - I do need to leave the bonnet on latch but CTEK is indoors. Picture attached.
Old May 12, 2020 | 01:19 PM
ShadyJC's Avatar
2018 E400C4
Cool, thanks!
