MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   E-Class (W213) (https://mbworld.org/forums/e-class-w213-208/)
-   -   Mercedes w213 Ambient Light doesn't work properly (https://mbworld.org/forums/e-class-w213/800646-mercedes-w213-ambient-light-doesnt-work-properly.html)
TomaszKrupicz Nov 29, 2020 09:41 AM
Hi,
i have a problem with my Ambient Light in E-class W213, 2017. The left part doesn't work, please see the picture.
https://cimg9.ibsrv.net/gimg/www.mbw...5986437025.jpg
I have also read a trouble code with my Autel MaxiAp200:
"Communication with one or several color generation and coupling modules on Lin Bus 7 is faulty"
https://cimg2.ibsrv.net/gimg/www.mbw...f455baee86.jpg
konigstiger Nov 29, 2020 02:04 PM
2 Attachment(s)
See attachments released by MBUSA they cover 2018 but you do not list your location in some markets 2017 = 2018 USA. Should be covered by warranty, you need to have someone check using Xentry (MB diagnostics).
TomaszKrupicz Nov 30, 2020 06:07 AM
Thanks for your prompt reply, attached Docs and your advise.
I have alreqdy called MB and they told me that my Car is not included in This Warranty-Action (I bought a car in Germany)
Could you please just tell me why you assume, that this is a problem related to the update of the software? Have you had a similar issue before?
abdulaziztda May 6, 2021 02:10 AM
I have same issues same car
Did you find a way to fix it ? If yes please do let me know how? Because I’m having the same issue on my car its e300 2017
​​​​​​​thank you so much
TomaszKrupicz May 6, 2021 05:45 PM
Yes, i fixed it!
check all the led lights (are all the lights ok?), when one is not working, that mean the circuit is not closed and the rest of the lights in this circuit will not work either.
In my case, the led lights in the space where the driver and passenger keep their legs were not connected, that couse a problem.
Quite easy thing, but tricky if you dont have a wiring diagram.
There is also probabilty that the LED is broken, but I do not know what kind of message you would find in your diagnostic device.
LP14 Nov 7, 2021 01:11 AM
Wiring diagram
Hi. I have the same problem with the dash ambient lighting on my 2017 e220 coupe. I’ve noticed that the footwell ambient lighting isn’t working either so I presume this is exactly the same problem. Where can I get a wiring diagram as you suggest?
PeteFIN Aug 28, 2022 02:28 PM
Originally Posted by TomaszKrupicz (Post 8330834)
Yes, i fixed it!
Hi,
i have same problem with my Mercedes E350e like your picture shows.. How you fix it ?
LP14 Aug 28, 2022 05:14 PM
The initial picture on this thread precisely replicated my fault and I found it useful to show the dealer. I initially took mine to the local Mercedes dealer and they charged me £80 for an diagnostic but they couldn’t find the cause of the fault. I asked them to check the wiring in the footwell and hey presto - the wires weren’t properly connected! This was easily rectified (apparently) and the LEDs now work perfectly. They charged me £50 for the work.
PeteFIN Aug 29, 2022 02:55 AM
Hi LP14, maybe this is stuppid question, but what is presto wires?
konigstiger Aug 29, 2022 11:13 AM
Reference bulletin 067044 to have dealer initiate repair process: https://mbworld.org/forums/e-class-w...ml#post8213433
LP14 Aug 29, 2022 03:03 PM
“Hey presto” - a figure of speech!
mohamin Dec 21, 2022 02:01 AM
E300 - Ambient Lighting Out Half Way on Driver Side
Yes, i fixed it!
Hi,
i have same problem with my Mercedes E300 like your picture shows.. How you fix it ? exactly same issue in driver side and driver foot Ambient Lighting Out Half Way on Driver Side
mohamin Dec 21, 2022 02:03 AM
Hi,
mohamin Dec 21, 2022 02:04 AM
Hi,
i have same problem with my Mercedes E300 year 2019 like your picture shows.. How you fix it ? exactly same issue in driver side and driver foot Ambient Lighting Out Half Way on Driver Side
PeteFIN Dec 21, 2022 04:41 AM
Originally Posted by mohamin (Post 8689517)
Hi,
My car was MB service in August 22.. they change new auxiliary battery to my car, and then problem came. So my problem was poorly attached wiring harness.. due to which the lights partially dimmed
BR
Petri
mohamin Dec 21, 2022 05:28 AM
BR
Petri
My Car had issue with auxiliary battery as well , i took it off , recharge it and re-install it again , the problem came as well , so can you please point out in picture where was the poorly attached wiring harness that you re-attached it well to fix that the lights partially dimmed ? i think i have the same exact issue , if you pointingout where i can attach the wiring harness well that would fix my problem i think .. waiting for your help ASAP please
mohamin Dec 21, 2022 05:32 AM
Hi PrteFin,
My Car had issue with auxiliary battery as well , i took it off , recharge it and re-install it again , the problem came as well after re-installation , so can you please point out in picture where was the poorly attached wiring harness that you re-attached it well to fix that the lights partially dimmed ? i think i have the same exact issue , if you pointingout where i can attach the wiring harness well that would fix my problem i think .. waiting for your help ASAP please
PeteFIN Dec 21, 2022 09:54 AM
Hi, sorry i don’t really know what was poorly attached cable.. because car service fixed that.. same who change battery for me. Did you disconnect any wiring harness.. there maybe some contact problem.. double check👍
onurkose Dec 29, 2022 09:32 PM
Same Problem and More - brand new GLE
Originally Posted by TomaszKrupicz (Post 8213308)
Hi,
I got my 2023 GLE 3 weeks ago after a 3 month wait.
2 days ago, my dashboard (speed & rpm screen went black, not the info screen) didn’t work for a few hours. After many restarts and a couple hours it came back to normal.
https://cimg5.ibsrv.net/gimg/www.mbw...4e9cc5768.jpeg
Dashboard not working. From 2 days ago. See the ambient lighting “red” working.
Today, the ambient lighting partially stopped working. Only the drivers door working, the rest of the ambient lighting is not working.
https://cimg5.ibsrv.net/gimg/www.mbw...d1cb68f26.jpeg
Dashboard works now. Ambient lighting only works partially. Only drivers side works. See the mid console and the replay of the car doesn’t work.
I got out of the car and locked the doors thinking that a fresh entrance would fix the lights, as soon as I touched the door handle, the car unlocked and all the windows went down on their own at the same time.
I am taking the car to the dealer in the morning. Hopefully they can fix it.
pgz Jan 25, 2023 05:55 PM
Hey any updates as what happened ? This is happening to me in my 2019 e300 as well
hey I was wondering if you found the fix of this cause ? This same issue is happening to me but I warranty just ran out
Sandromadruga Feb 14, 2023 06:44 AM
I have the same problem. managed to solve?
Raul92 Feb 20, 2023 06:59 PM
Air filter in the cabin
I had the same problem and I started looking on the internet without realizing that I had changed the pollen filter.
What I mean is that when you change the pollen filter on the right side of the driver, the plastic that will have to be disassembled will be 2 threads
One is for the temperature sensor (the warm air that will circulate the car) and a second for the light under the feet.
When disconnected it will turn off the lighting under the feet of both front passengers and half the lighting on the driver's side (as in the presentations above)
Try to see if these 2 contacts are well put back in place, to me that was the problem and I would not have realized if I had not changed my pollen filter myself.
Excuse me if I made mistakes in expression
Raul92 Feb 20, 2023 07:06 PM
Ambient light wiring
Hi,
I'm trying to give an answer here so that we don't look for another answer if this resolution of mine is beneficial to others.
I had the same problem and I started looking on the internet without realizing that I had changed the pollen filter. What I mean is that when you change the pollen filter on the right side of the driver, the plastic that will have to be disassembled will be 2 threadsOne is for the temperature sensor (the warm air that will circulate the car) and a second for the light under the feet. When disconnected it will turn off the lighting under the feet of both front passengers and half the lighting on the driver's side (as in the presentations above, It is seen that even the ambient light does not work at the feet anymore) Try to see if these 2 contacts are well put back in place, to me that was the problem and I would not have realized if I had not changed my pollen filter myself.
It is possible that sometimes after service B or A (when replacing air filters) some "craftsmen" forget to put back the two wires Excuse me if I made mistakes in expression
Singapore 2023 Jul 9, 2023 06:32 AM
excalty, the light wire did not install back after changing the air cabin filter
W205C43PFL Jul 9, 2023 09:36 AM
Glad you discovered it, might be the cause for others' ambient lighting not working after all.
© 2026 MH Sub I, LLC dba Internet Brands
