2002 E320 ESP visit workshop
2002 e320 base
Hello Mercedes forum, having issues with my 2002 E320 with ESP visit workshop popping up periodically while adding BAS light to it's display in the lower left hand corner. Car has 228,00 miles. When ESP light comes on after engine is warm, I lose blower motor and turn signals for about 1-2 minutes. Losing these features doesn't happen all the time. Those features come back and ESP light stays on. Sometimes restarting the vehicle removes this error. Installed a new battery and tried the left to right steering reset. Still have the problem.
Received 4,447 Likes
'71 Pinto
Check control unit for moisture, etc. If fine best to have someone pull fault codes using MB diagnostics. Assuming vehicle is 211 (2nd photo) and not MBUSA market should be posting here: https://mbworld.org/forums/e-class-w211-20/
2002 e320 base
You are correct, my vehicle is a 2002 W211. Exactly as the upper picture shows. Thank you, I'll check this area. Vehicle should have been 2002
'71 Pinto
