20 Tire size recommendation
The 20x8.5 around should be OK, but check the ET/offset value on these wheels and check it on all 4 of them.
I think the tires will physically fit in a W213 but - 245/45 is a tire with 730mm diameter (109mm sidewall). The stock diameter on the W213 is around 680mm. This will make your speedometer off by about 7% (you will be going faster than what it is showing).
You can play with wheel and tire sizes here: https://www.wheel-size.com/calc/
There are number of other posts on the topic of wheel sizes and tires.
Ive search the forums but I dont see a lot about 20 tire size for square setup.
So I just found out the offset on the wheels Im trying to get(Vossen HF-3), per their website it shows +40 for their 20x8.5
This is what 20" (8.5 front, 9.5 rear, ET35) look like, with 255/35R20 tires on both front and back (the rear tire looks more stretched on the wider rim).
I happen to come across carid.com and seen the exact same wheels. As Im trying to build it, the only tires size they have as an options are 245/35. But 245/40 sounds more appealing with higher sidewalls.
I want to find out too i have 20" rims with 245/40/20 and 285/35/20. The offsets should work 35+ fr 41+ rear
Tires are from a c217 S550 coupe oem sizes.
