W213 OEM654 CAN-bus problems
As the OBD reader indicated problems with the NOx-sensor and the temperatur sensor for the air intake both were replaced and in addition the car got a new battery. Instead of an improvement the engine warning light is still lit and in addition the car is running in some emergency program which allows a maximum of 2.200 rpm and 200 Nm. The OBD reader says "CAN-Datenbus Daten Motorsteuergerät unplausibel" which I would translate to "CAN-bus data of engine ECU inplausible".
My workshop seems to be somehow stuck with the problem. Any hints from this forum regarding a possible cause and a solution for this problem?
Use a scanner to retrieve the DTC NUMBER to help understand your diesel issue.
The Diagnostic Trouble Code that was retrieved with the engine off was U0401E5 (attachment).
When the ECU is powered you'd expect that message to go away. (Electric Steering usually shows that without engine running... totally ok!)
When a CAN bus is down, you are going to get MANY related errors about missing modules. What are the impacted modules, CAN E1 ?
Thx again for your advice.
