E-Class (W213) 2016 - 2023
Does your E class bottom out too much?
Old Jun 14, 2022 | 05:48 PM
The G Man's Avatar
2019 E300
I have a 2019 E300 sport and I would say the car bottoms out more than I expected. I live in Boston and the roads are horrible here, my car bottoms out once a month on average. I expect this from a sports car but not a mid size luxury sedan, 95% of time, the car rides beautifully, so I put up with the other 5%. I am not sure if this is due to the E class’ soft suspension coupled with a short suspension travel. Just wondering if anyone else is experiencing the same.
Old Jun 14, 2022 | 07:17 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
I have a 2019 E450:
Nope never has happened - but then again I do not have the lowered sport suspension. I have the Luxury Styling with standard 18" wheels.
Old Jun 14, 2022 | 07:21 PM
kingscorpian27's Avatar
MB W213 E300 4MATIC Luxury Model
2017 E300 Luxury model with 17” rims and
regular non-run flat tires. Great ride no bottom out issues
Old Jun 14, 2022 | 09:06 PM
The G Man's Avatar
2019 E300
There is only a 10mm difference in suspension height between the sport and luxury, hard to believe that would make much of a difference.
Old Jun 14, 2022 | 09:21 PM
TennesseeZ4's Avatar
2019 E450 wagon: 2019 BMW 430i: 2013 Chevy Traverse: (departed)2013 SL550 & 2019 E450 cab
Had the same issue with our A238 2019 model: this is what I found in MB literature: In the MB E class intro information, they post the following on the Agility Control with selective damping system:
The comfortably tuned, conventional suspension / damping of the E-Class is designed as a road surface-dependent damping system. The front axle suspension strut is attached to the body with a triple-path head bearing. With this system, the static carrying forces are transmitted directly to the body via a plastic shim. Large forces (e.g. when shock absorbers bottom out) are absorbed by a jounce buffer.
The function module consists of a small elastomer piston, which reduces the damping effect in the event of minor road surface excitations. This considerably improves the driving comfort and the response of the suspension in particular. For heavier road surface excitation, the full damping effect is available.
It goes on to show the diagram of the strut assembly, showing the components, valves, etc.
All that being stated, our 213 wagon on 18" rims is much more forgiving than the 19" rims on the A238. Bottom line, the lowered suspension in certain circumstances will feel more harsh on the larger diameter rims.
Old Jun 14, 2022 | 09:35 PM
The G Man's Avatar
2019 E300
I imagine when it bottoms out, it hits the bump stop or jounce buffer on the struct. Your A238 has sport suspension I imagine, does your wagon bottom out as well?
Old Jun 15, 2022 | 09:48 AM
So the short answer is sometimes, like when I encounter the pot hole from you know where. But in normal, and spirited, driving there is simply not the same sensation that the A238 suffered from, which was a pronounced shuddering when the suspension would bottom out onto the shims. While my wagon also has the lowered adaptive suspension, it also has 18" wheels, and I believe that somewhat mitigates the impact jounce. What I also found is that the suspension does not bottom out as much with the suspension setting on sport. I program my individual setting to be comfort for engine, sport for suspension and steering; that gives me the best ride feel. Worked on both vehicles. Following links to additional discussions / information from MB.
I have a pdf of the press release that has detailed photos of the front strut assembly, showing the components, including the head bearing buffer; should you want to see it, send me a PM with an e mail address.
MB Press Release: https://group-media.mercedes-benz.co...ml?oid=9271757
Previous discussion on this forum: https://mbworld.org/forums/e-class-w...ng-system.html
Old Jun 15, 2022 | 10:31 AM
The G Man's Avatar
2019 E300
Thanks TennesseeZ4 for your response. Seems like the sport package in the wagon is a bit different than the sport suspension in the cabriolet. For roads in the Northeast, maybe all terrain is the way to go.
Old Jun 16, 2022 | 05:43 PM
skytop's Avatar
Only when Burt Reynolds is driving over an opening bridge. Landings are very hard.
Old Jun 16, 2022 | 09:30 PM
First-e320's Avatar
2015 C450; 2008 RX400h
I had a 2018 e300 with terrible bottoming out of the suspension. Of course, the dealer said there was no issue. However, there is one spot on a road I travel that would always bottom out the suspension with a big bang. I travelled that same road with many other cars and had no issues, and those cars include a 2016 c450, a 2021 Toyota Hybrid Highlander, and a 2019 Mazda 3. As far as I am concerned, this is a design fault. Very disappointed with Mercedes and this terrible design.
These are what my rims looked like:
https://en.wikipedia.org/wiki/Merced..._2.0_Front.jpg
Old Jun 17, 2022 | 07:57 AM
The G Man's Avatar
2019 E300
Seems to me the W213's suspension does not handle the dips on the potholes too well, it seems to handle the speed bumps better. In the Northeast, this time of year the potholes are mostly fixed and the Biden money started a lot of new road paving projects. In the Winter, the pothole bottoming out will repeat.
