W213 inner tie rods replacement
Hi, I need to replace my inner tie rods. Is there any machined surface and enough room on the steering rack side of the shaft so that I could put an open wrench to pull against while loosening the inner tie rod? I mean, I want to avoid putting too much load on the steering rack and possible damage while unscrewing the tie rod.
Then, I read somewhere that on W211 or W212 (not sure) a torque of 110NM is to be applied on the inner rod to the steering shaft. Is this valid also for W213? What tool do you use? Or would it be enough to tighten it just by hand as much as possible by using a thread lock?
Thanks.
Thanks.
I'm sorry, I don't have any experience with this to share. However, I'm curious about your W213. and this wear point. How many miles and are you mostly city driving? Thanks and good luck with the fix.
Thanks.
Thanks.
Hi, I went through plenty of videos related to W211 or W212, no one ever used a torque wrench. Furthermore I asked some mechanics and they do not use it for this kind of job. I have several torque wrenches but I believe there must a special tool for this because none of mine suits and I have never seen any that would.
