E-Class (W213) 2016 - 2023
2017 Mercedes-Benz E300- Very slow wireless charger!! Any fix?
Old Oct 6, 2024 | 03:50 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
Originally Posted by Massimo Here
I think with everything that I read- wireless chargers have never really took off because they're not as fast as plugging your phone in to a wall socket.
Not to mention they can produce more heat which is not good for the battery and also in the car your alternator fluctuates with voltage, taking off or coming to an idol that may not be good for your battery as well.
So I have an actual socket in my Mercedes I just use that now, it just works better and fast charges with no heat! 🙂
I've been using wireless almost exclusively for the past 3 years and don't have any issues. The only time my phone is ever charging with a cable is when I'm on the motorcycle. At home I use a wireless charger on my night stand and use the wireless charging in the car. I do not have issues with heat or slow charging. I do have to take the case off while in the car but not when it's on my home wireless charger. I think the majority of issues are the many cheep wireless chargers out there. Not all are created equal. I've had a few that were junk.
Old Oct 9, 2024 | 03:17 PM
ua549's Avatar
I fast charge my Phone, notebook, etc. to 100% at home each morning while I'm having coffee. The phone charge is good for a couple of days if needed. My notebook needs charging every 7-8 hours.
Old Oct 9, 2024 | 04:15 PM
W205C43PFL's Avatar
That is pretty nice battery life, how is your phone usage, is it possible you use the notebook more than the phone? Does the notebook have a limit charge option to proect the battery and you can simply plug it in all the time instead?
Old Oct 9, 2024 | 08:02 PM
ua549's Avatar
My phone, Galaxy S24, is used almost continuously for text and email (3 accounts), almost no voice.
My notebook is a top end 2024 HP Spectre x360. It gets heavy use for spreadsheets, database, network management, email (6 accounts), web and forums. The notebook is usually away from wall power, so it gets charged to 100% whenever possible. It is used 10 hours per day and is never turned off. The battery is rated for 12 hours. I get 7 or 8 hours, if lucky.
Right now my notebook is connected to the internet via my cell phone hot spot. Our power has been out for hours courtesy of Milton. I have an 8kw generator.
Old Oct 9, 2024 | 08:16 PM
CarFan1's Avatar
Porsche Cayman S, Mercedes W213, Nissan Titan, BMW X5, Chevrolet Suburban
Stay safe!
Old Oct 9, 2024 | 08:38 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
I use these in all my cars now.
【Upgraded】125W USB C Car Charger Super Fast Charging for iPhone 16 Pro Max, [PD65W & QC60W][All Metal] MRGLAS Cigarette Lighter Car Charger,Dual Port for iPhone 16 15 Plus iPad Samsung S24 S23 MacBook https://a.co/d/7A6O2dy
Old Oct 9, 2024 | 08:41 PM
  #32
We just got back from tooling around in the golf cart....in 40mph gusts :-)
Old Oct 9, 2024 | 09:02 PM
  #33
W205C43PFL's Avatar
I see, understood, I must be doing something wrong because I have pretty much the same phone and only have two days of battery life and most of the time 1.5 days.
As for the laptop, I see, with such usage it makes more sense now.
Thank you for your response and your answer to my curiosity.
Old Oct 11, 2024 | 03:48 PM
  #34
Cosworth2000's Avatar
2022 E53 AMG
Wireless charging was never created to fast charge. If you want to fast charge, it's a software that activate the fast charge and connected to the port of the USB-C.
Old Oct 12, 2024 | 09:19 AM
  #35
Roman living's Avatar
Yeah in 2024 I still find them not practical so like I said earlier I found an actual socket in the Mercedes for the backseat drivers I just use that and it fast charges and it's probably more of the correct voltage because again you have to also consider alternators fluctuate in voltage which may not be good for the phone!
Old Oct 12, 2024 | 09:45 AM
  #36
ua549's Avatar
My '18 E300 has 12v power sockets conveniently located throughout the cabin. My car also has a 110v outlet on the rear of the center console.
Old Oct 12, 2024 | 12:05 PM
  #37
L1Wolf's Avatar
Veteran: Army
W214 E450
I don't think I'm following you here. What does "backseat drivers" mean? You found a socket in the back seat?
Regarding alternator and the fluctuating voltage. That is not the case in today's modern car. The DC is clean and doesn't fluctuate voltage. Although I'm confused as to what this socket is that doesn't have this perceived DC fluctuation. Unless it's an AC plug and you are using your own AC to DC converter, you are getting the DC produced by the car. The 12V auxiliary ports (otherwise known as cigarette lighter ports) and any USB ports are all DC supplied by the car. The voltage of all USB ports is 5V. The watts are what determines the ability to fast charge. If using the 12V auxiliary port with a USB charging adapter then you should know that many are junk. My bet is that you won't find one that is any better than the car USB ports. There are USB port testers on the market that can tell you the voltage and watts. If you are concerned, you can get one and verify your cars USB ports.
Old Oct 12, 2024 | 12:09 PM
  #38
In the back at the bottom of the center console for the back seat drivers there is a USB port and an AC outlet in my 2017 Mercedes E300, maybe yours didn't come with it.
Old Oct 12, 2024 | 12:18 PM
  #39
L1Wolf's Avatar
Veteran: Army
W214 E450
I don't believe I do. I have 6 USB ports with a combined 100W max for charging or supplying power to almost any USB powered device. And then two 12V auxiliary ports.
Old Oct 12, 2024 | 03:43 PM
  #40
ua549's Avatar
The 115v outlet option U80 was $115 as shown on the Monroney label.
Old Oct 12, 2024 | 06:34 PM
  #41
L1Wolf's Avatar
Veteran: Army
W214 E450
That is not an option on the W214. Not sure why.
Old Oct 12, 2024 | 10:21 PM
  #42
This is what mine looks like I use it for charging my phone, it fast charges and works much better than my USB or cigarette ports!
