Airmatic Diagnosis
I walked out to my 2017 E43 this morning when I saw the car was leaning down towards the back right tire. It wasn't slammed, but noticeably sagging. Anyway, I hit the unlock button on the key and the compressor came on for ~7 seconds and raised the back right. I did not observe if the back left was also sagging or not.
My question is: how can I diagnose the system? As far as I know, it could be the valve block, air bag, or air strut, correct?
I just purchased the car and had it inspected via my indie mechanic. He did not mention anything about the airmatic, so I assume the bags must not be dry-rotted or anything like that?
Any insight is greatly, greatly appreciated. I am worried.
But you’ll need to diagnose whether it’s an air line leak, valve block failure or actual air bag leak.
Soapy water is one way to look out for it. Or this:
Regarding the bag/strut--I believe that's correct for the fronts, that they are one unit. But in the rear, they are separate, no?
If so, which unit generally holds the rear of the car up? I'd assume the bag itself but not sure. I've seen on YouTube that the struts generally last a significant while longer than the bags.
Anyway, I checked my car this morning (it should have been sitting for the same amount of time as last night) and the car was not sagging on any corner. I unlocked the car and Airmatic actually vented a corner rather than having the compressor come on. I will monitor for the next few days and replace the valve block soon. All of a sudden, I feel like a doctor.
I'll update this thread or create another one for a valve block / airmatic filter (if the W213 has one...) replacement guide when I do so, my contribution to this forum.
Hopefully that's all my car needs... for now.
i did some YouTubing, and it appears that rears always have had a separate airbag aside the strut. From the look of things, if
yours is an air hose leak, the hose will be way cheaper but you will likely have to take more of the panels off to access and replace the air line.
Since it’s not collapsing hard or immediately sagging every time, it’s still pretty early stage, but honestly without pulling codes from the Airmatic control unit and checking stored leveling faults, you're mostly guessing at whether it's a valve block or bag issue. Have you tried spraying soapy water around the rear bags and air fittings yet after shutdown to see if you catch any bubbles forming? That would be the first easy check I'd do before replacing parts.Here is a video that may help as weell.
The car has not sagged since 4/22 despite sitting for ~ the same amount of time (the compressor has not come on with unlock from the key, and I crudely measured wheel-to-fender with my mini iPhone--nothing seems to be off except for occasional venting of a corner because it's too high, attributable to air temp/pressure changes?)
If there were a leak in the bag, it would leak down overnight, very consistently, correct? And the car adjusts Airmatic on the actual UNLOCK (when the door actuators do their thing etc...) with the key rather than sensing the key come up to the car?
Along with the valve block, does anybody know if the W213 has an Airmatic filter, and what the part number is? It's very hard to imagine the system is entirely unfiltered. I questioned FCPeuro via email, and checked EPC to no avail.
"Unfortunately, we don't seem to carry the Air Compressor Filter for your application. I wasn't even able to locate a part number for you. I'm very sorry."
Is there anybody who could help me locate a part number if/for an airmatic system filter for the w213? FCPeuro, ECS, and Arnott were unable to locate one for me. I checked through some version of EPC but am still unable to find the part.
I really don't want to disassemble my car before having the part in hand.
I also can't quite believe that the w213 doesn't have an airmatic filter at all, if it really doesn't. Perhaps the pump has a screen that has to be cleaned or something? No way MB would let dirty air and contaminants get into the system... right?
I just realized it may also sip filtered air from the cabin dust filter or engine air filters, pre-MAF. No idea how to verify that though.
