E-Class (W214) 2024 -
Awful Wiper Noise
Old Dec 16, 2024 | 08:45 PM
rp5611's Avatar
2024 E350 4MATIC (W214)
Angry Awful Wiper Noise
Since I got the car, the wipers have been jumping/chattering across the windshield. I have tried numerous suggestions found on forums but to no avail.
Here are the things I have tried
- Polished the windshield
- Waxed the windshield
- Applied NuFinish
- Tried with nothing on the windshield
- New OEM wiper blades
- New aftermarket blades
- Replacing only the rubber on the OEM wipers
- Silicone spray on the blades
- Clay bar on the glass
- Adjusting the wiper arm tension
- Dealership buffed the windshield with a "special cleaner"
I have tried all of these, yet nothing has helped. At this point, the wipers drive me crazy every time it rains...
Has anyone else experienced this and found a solution that works?
Old Dec 16, 2024 | 08:55 PM
FSmith's Avatar
2024 E450 2024 GLE350
- Applied NuFinish
Mine were 100% quiet. So quiet my wife commented on how quiet they were 😂. Then I ran it through a touchless car wash. Now the passenger side chatters and is noisy. At least in my case it has to be the car wash wax on the windshield. I was going to order the cleaner Mercedes recommends but it might not work assuming that’s what your dealer cleaned yours with.
Old Dec 16, 2024 | 09:45 PM
W205C43PFL's Avatar
Yes that makes sense, another thing is it doesn't like RainX.
Old Dec 19, 2024 | 10:46 PM
rp5611's Avatar
They are quiet now thankfully!
I tried a different glass polish, then loosened the tension of the wiper arm springs a little and adjusted the angle of the arm
Old Dec 20, 2024 | 03:49 PM
FSmith's Avatar
What polish did you use?
Old Dec 21, 2024 | 10:23 PM
rp5611's Avatar
I used griots fine glass polish and went over the glass with a DA polisher
Old Dec 31, 2024 | 07:59 PM
liexpress's Avatar
2024 E450
What windshield fluid do you use? I know Rain-X is bad for MB.
Old Dec 31, 2024 | 09:12 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
That is certainly not true.
In 2015 a class action law suit against Rain - X was initiated.
The action was then dismissed in 2017.
The final settlement was limited to Mercedes between 2013 and 2017.
see:https://www.classlawgroup.com/rain-x...-investigation
see: https://www.classaction.org/rain-x-lawsuit
see: https://www.courthousenews.com/wp-co...347c45d2-2.pdf
Today Rain X windshield wiper fluid is as good as any other: Point of fact I have been using it for over 6 years without any problem.
However I would never put Rain X, or any other product on my windshield. Clean glass is the best.
Old Jan 1, 2025 | 11:53 AM
ua549's Avatar
I agree with JTK44 that plain water is the best. I use the same distilled water that I use in the kitchen because Pinellas County water contains low levels of several inorganic contaminants, disinfectant byproducts, lead and copper.
Old Jan 2, 2025 | 02:27 PM
liexpress's Avatar
2024 E450
Good to know that. I saw mixed reviews after 2018 regarding whether Rain-X damaged sensors or clogged the nozzles. If rain-x hasn't changed their formula of windshield fluid since 2017 or mb hasn't made their sensors stronger, it could be risky.
I haven't added Rain-x windshield fluid to my car yet, but I applied their windshield treatment product and the wiper began to make noise right away - much better now as it been washed away gradually.
Old Jan 2, 2025 | 02:33 PM
liexpress's Avatar
2024 E450
Great for Florida, but certainly not for New York.
Old Jan 2, 2025 | 03:18 PM
JTK44's Avatar
The lawsuit was for years 2013 - 2015. It was dismissed then settled with small amount to each claimant - less than $200 each.. I am sure the formula for the windshield washer was re-constituted as a result of the lawsuit.
I trust Costco: That is where I buy my Rain-X windshield fluid.
Wipers work best on plane clean glass. When I put Meguiar's Ceramic Hybrid wax was on my car, I try as best as I can, to keep the wax off of my windshield. Works fine on the side and rear view windows: water beads up nicely but when it gets on the wind shield the wipers can chatter.
Old Jan 5, 2025 | 10:20 AM
snarestud940's Avatar
2024 Mercedes-Benz E350
This happened to me when I first bought the car in July. Now, it happens once in a GREAT while! although, I go to the car wash every week if not twice a week so I'm sure the windshield was worn down. But seems to work great now.
