Speedometer calibration
For some of us with larger tires on older trucks, we use a speedometer adjustment device and can get the info dead on.
Regardless of any of this, a brand new vehicle with stock tires should be dead on at all speeds considering this was achievable decades ago before they stuck leashes in our asses to track us while we pay them for the opportunity.
A better, but still inaccurate method would be to drive at 60mph on an interstate for exactly 60 minutes and start a timer while resetting your trip just as you pass a starting reference mile marker. At exactly 60 minutes look at the odometer and take note of the mile marker you just passed or are about to pass and do the math for the distance traveled. If that is close (within 1/3 of a mile) to the odometer than your odometer is likely pretty accurate. If your speedometer is off by +2mph at 58mph and your odometer was equally off, you would expect to be passing the 58th mile marker at 60 minutes while your odometer says 60 miles driven. There are many factors that will cause this to be imprecise such as the true distance of mile markers on the interstate, your ability to reset your trip and start a stop watch at the exact same time, the fact the odometer trip only shows accuracy to 1/10th of a mile (528 ft), and your ability to estimate how far you are from the nearest mile marker at exactly 60 minutes. That's why you would need to travel a long distance such as 60 miles to make these factors insignificant. You could increase the distance to say 120 miles to reduce the impact even more. By the way, I wouldn't recommend anyone try this without a co-pilot for safety reasons.
