E-Class (W214) 2024 -
Retractable Door Handles
Old Feb 25, 2026 | 07:54 AM
  #226
Roweraay's Avatar
X214
Originally Posted by regor60
CD is independent of frontal area. Drag area is what counts, which is CDxFrontal Area.
That’s interesting. I would have thought that a larger frontal area (as opposed to a sleeker/aerodynamic frontal area), would increase drag. The air resistance that the car has to push through, would have more frontal area to manage, thus increasing drag, the way I am thinking.
Thus by reducing the frontal area and making it sleeker/slippery, and then shaping the rest of the car to allow the air to flow through with less impedance, should in theory result in a better Cd number, but I have not studied this in too much detail.
Old Feb 25, 2026 | 07:58 AM
  #227
Richbot's Avatar
'26 E53 | '08 E90M
Right - You can make a perfect teardrop that has a Cd of 0.10 but if you make it the size of the Hindenburg you’re still going to need a lot of power to push it through the air - increasing length of the body does help with Cd, generally. And a wider front vs rear end, if you employ it correctly, can help shape the way the air flows over the rest of the car - but generally frontal area is still going to subtract more than it adds to your efficiency.
Old Feb 25, 2026 | 05:21 PM
  #228
regor60's Avatar
06 E55 Black
Your prior post said that the drag coefficient remain the same despite an increase in frontal area. I'm just pointing out that the drag coefficient is independent of the frontal area and reflects the aerodynamic efficiency of the area.
So for example you could have a vehicle with a larger frontal area than another vehicle but with a superior drag coefficient yielding a lower drag area number and therefore a lower energy loss to drag​​​​​
