E-Class (W214) 2024 -
Retractable Door Handles
Old Jan 20, 2026 | 03:43 PM
  #151
Alan Smithee's Avatar
Originally Posted by elmalo
To sum up: Retractable door handles don't open or close the door any better than fixed door handles but are more complex, unreliable and more likely to fail. Bringing up aerodynamic drag as an excuse is ridiculous. First, the overall drag coefficient is insignificantly reduced by retractable door handles as compared to fixed recessed handles, and second, aerodynamic drag depends on the speed of the car and the average speed of daily beaters is very low.
I'll just leave this here. You are certainly entitled to keep yelling at the clouds if it makes you feel better.
https://media.mbusa.com/releases/a-b...he-new-e-class
Efficiently and quietly through the wind
The new E-Class: aerodynamics and aeroacoustics
  • Very good aerodynamics with a Cd figure from 0.23 and a frontal area A of 25.4 ft2
  • A great deal of detailed development work, with some innovations adopted from Mercedes-EQ models
  • Extensive measures against wind noise, measurement procure using almost 500 microphones
With a Cd figure from 0.23, the new E-Class performs very well in its vehicle segment and matches the excellent value achieved by its predecessor at market launch. It is remarkable that this high level has been maintained with only a slight spread between the individual variants, because certain factors make aerodynamic performance more difficult such as the wide wheel portfolio from 18 to 21 inches as well as the rear-axle steering with additional steering arms and larger underbody cavities. At 25.4 ft2, the frontal area A of the new E-Class is slightly larger than that of its predecessor (25.1 ft2).
Many computer simulations at an early stage increased the degree of maturity and allowed for fewer optimization loops in the wind tunnel. In close cooperation with their design colleagues, the aerodynamics team has specifically improved the E-Class in numerous areas. Some details such as wheels with cladding inserts were adopted from the famously efficient Mercedes-EQ models. The most important measures include:
  • Optimized contours: even including the tires
  • Innovative sealing of the front section: for the first time with side-sealing of the hood and an aero-lip in the radiator grille
  • Wheels with claddings: so-called "aeroblinds"
  • Special spoilers ahead of the front and rear wheels
  • Flush, retractable door handles
  • Underbody: new materials (2-component main floor with molded-on sealing lips) and improved shape (ramp-shaped spoiler lips, aerodynamic cladding on suspension components)
"Acoustic camera" and "acoustic holography" with almost 500 microphones
When it comes to aeroacoustic development, Mercedes-Benz always takes a dual approach: on the one hand, as little noise as possible should be generated at the source, i.e. when the air flows around the outer skin of the vehicle with all its mounted parts. And on the other hand, the quality of the sealing and sound insulation help to ensure that unavoidable wind noises are hardly perceptible in the interior, or not perceptible as disturbing.
During the early development phase, the engineering team began to configure the geometric dimensions of the A-pillar and the exterior mirrors, which are particularly relevant for noise generation, accordingly. Advanced development methods using flow simulations and noise measurements were combined when optimizing shapes: For the latter, a special microphone array was used in the acoustic wind tunnel. The extensive interior measurements are also called "acoustic holography". In this process, Mercedes-Benz uses 64 double microphones in the interior (hand array), which can locate problem areas in low-frequency ranges. Including the devices for outside measurements ("acoustic camera"), Mercedes-Benz uses almost 500 microphones.
The high-frequency components of the wind noise were reduced by a variety of measures in the door seals, side windows and exterior mirrors. The structural rigidity of the doors was increased in the relevant areas. At very high driving speeds, this results in less wind noise. Cavities are foam-protected to improve the acoustic insulation in the body-in-white. This affects the structure of the cockpit cross-member and areas of the transmission tunnel and the A and C-pillars.
In the panoramic sliding sunroof, many detailed improvements were made to the wind deflector and by adding side wind deflectors to the glass roof. The result is better noise comfort and reduced draughts. In the tilt position, the glass panel is lowered depending on the vehicle speed. This also ensures pleasant interior acoustics and reduces actual aerodynamic drag.
Old Jan 20, 2026 | 03:51 PM
  #152
geektoad's Avatar
26 E53 Wagon
Power windows can be controlled remotely, manually cranked windows can not.
Ok. you win. Have a cookie. Also maybe find a hobby, other peoples' cars really shouldn't bother you this much.
Old Jan 20, 2026 | 04:09 PM
  #153
elmalo's Avatar
2015 S-550
Originally Posted by GregTR
The issue is bias. These "ideas" are always tested many times over by engineers, designers, discussed by finance and bean counters and eventually put in front of focus groups who decide what is and isn't a "good idea". These people are not stupid but they're not infallible. What they are is biased. And it's very difficult to leave that bias behind to make objective decisions. And sometimes the things that were financially feasible, design and engineering possibilities that were even well received by focus groups and test users can end up flopping in the real market. With auto manufacturing, it takes 3+ years to iterate and fix which can feel like an eternity, especially when compared to software changes that can happen overnight.
So no, these are not "tested" on customers. They were already tested and deemed to be a net positive only to receive "some" backlash. Again, you're sampling a few griping people on a message board. You need to look at it in the context of all users, many whom are not represented here.
The people you mention also 'reviewed" and approved of the driver interface in current MB models where commands are via touchscreen or useless haptic buttons on the steering wheel. Sounds like they never tried the final product.
https://www.motortrend.com/news/merc...g-buttons-back
Old Jan 20, 2026 | 04:13 PM
  #154
elmalo's Avatar
2015 S-550
FYI, my last 9 cars have been MB, including 4 S-Class. I don't care what other people drive, I have my own opinions about cars I have been interested in buying.
Old Jan 20, 2026 | 04:18 PM
  #155
SW20S's Avatar
Active Streak: 30 Days
2024 S580
The only "buttons" they are bringing back are the physical volume wheel on the steering wheel and the physical control for adjusting the cruise control speed.
By and large the touchscreen and the haptic buttons are fine. Door handles not fine, buttons are fine.
Old Jan 20, 2026 | 04:39 PM
  #156
elmalo's Avatar
2015 S-550
Haptics and touchscreens are much. much cheaper than mechanical switches, which is the main reason for these mistakes. To work a touchscreen while driving is worse than texting.
Old Jan 20, 2026 | 05:20 PM
  #157
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
They look nice in the show room, improves the line of the door and makes me think my 2023 is getting old. Sorry to hear that their function is a bit off, but imagine that if they survive the software will improve and one day we will say 'wasn't it so quaint that people used to complain'.
Old Jan 20, 2026 | 06:36 PM
  #158
SW20S's Avatar
2024 S580
Touchscreens have been around for a LONG time, my old 2003 Lexus ES300 that is still in the family has a touchscreen, its not a new thing. I prefer a control on the console but the touchscreen isn't a big deal.
Old Jan 20, 2026 | 07:26 PM
  #159
elmalo's Avatar
2015 S-550
All depends on what functions are on the touchscreen. The more functions, the worse it is. There are cars where the vents are controlled via touchscreen, which is really dumb.
Old Jan 20, 2026 | 07:45 PM
  #160
SW20S's Avatar
2024 S580
Why don't you listen to some of us who have lived with this touchscreen after having also lived with the old system. MB's system does not control vents through the screen.
Old Jan 20, 2026 | 08:43 PM
  #161
I'm with you 100% on this, but the cockpit UX/UI is a completely different subject than retractable door handles.
Old Jan 20, 2026 | 08:53 PM
  #162
elmalo's Avatar
2015 S-550
Totally agree!
Old Jan 20, 2026 | 10:38 PM
  #163
CaprichioArabe's Avatar
E450 Wagon, GLC300, E550
It seems to me that more and more design elements of EVs are trickling down to all new cars. That includes the giant screens and the door handles. It is more economical for a car manufacturer to share design elements and parts across their line. It ideally, if not realistically, benefits the customer in reduced prices on new cars, reduced costs and increased availability for replacement parts, and reduced complexity of training for authorized repair technicians.
The touchscreens do not overwhelm me as much as the myriad of functions, features, and customizability that are provided to the user. All of that may be even more difficult to negotiate if it was all done through buttons rather than menus. Just scroll through all of the menu options for things like interior lighting, exterior lighting, courtesy sounds, media parameters, driving modes, vehicle status information, comfort controls including aroma and massage, safety alert thresholds, navigation preferences, etc. It is overwhelming, but the alternative would be not to offer them. Plus customers born after the baby boom generation have grown up with and are very comfortable with the use of haptic controls and touchscreens. I agree that it would be nice to have a nice large button for stereo volume, but dial-type controllers have a history of developing electrical shorts and other issues with prolonged use.
I have mixed feelings about the door handles, but I’ve found that they won’t “snap” inward if you simply hold onto them. They quickly stop allowing you to continue to pull them open. If you pull your hand away in a panic, they no longer detect you, but like electric window controls, they stop when they encounter resistance.
My local carjacker was humiliated trying to find the handle and now leaves me alone.
Old Jan 21, 2026 | 01:09 AM
  #164
geektoad's Avatar
26 E53 Wagon
ok....bye! noone cares what you think about cars you don't own, and what you have or haven't purchased in the past doesn't change that. TTFN!
Old Jan 21, 2026 | 12:05 PM
  #165
SW20S's Avatar
2024 S580
But, this is an example of poor design. You shouldn't't have to think about how you grab a door handle to avoid it behaving in an undesirable way. Maybe the solution is to have a button to lock that isn't touch sensitive, like Land Rover does:
That button is much harder to accidentally brush because its a physical button.
Or do what Tesla does and don't have a button to lock, let it just automatically lock.
Or do a flush electronic door handle like BMW.
Old Jan 21, 2026 | 01:05 PM
  #166
Richbot's Avatar
'26 E53 | '08 E90M
It's ok to observe any car has flaws. They all do.
As is tradition, four of the five main characters have appeared in this thread on this here internet car forum:
1) Original complainant
2) Obnoxiously dismissive marque fanboys (half of whom parachute in to the forum because the topic was on the front page)
3) Non-sequitur afficionados (it was the year 1993 and the W124 was nearly new and a gallon of gas cost twelve hapennies and therefore such as america thank you)
4) People who agree with the OP's complaint (attracting even more of #2)
5) Vendors selling usually unrelated things
I blame the lack of #5 on the newness of the 214
Old Jan 24, 2026 | 12:26 PM
  #167
Roweraay's Avatar
X214
Bingo ! The reason for eliminating the buttons/switches/knobs are cost-related. Not something the customers asked for.
As it stands, from dedicated buttons to do ALL of the audio controls, and ALL of the climate controls, now it has all been moved into a screen. Even if say I use voice commands, it is nowhere close to as efficient as reaching over a pressing a button.
Unfortunately, the way the wind is flowing, we will see more of this kind of cost-cutting, than less.
Old Jan 24, 2026 | 12:30 PM
  #168
Roweraay's Avatar
X214
How much of this lower Cd (achieved via a plethora or things, including reducing the rear hatch-height and reducing practicality) translates into real-world mileage improvement for the actual users ? Having been the owner of a 2022 E450 All-terrain, and now the 2025 E450 All-Terrain, I would say the improvements in the real-world are ZERO. In addition to the reduction in practicality to achieve a lower Cd on paper. You had a 2021/2022 All-Terrain yourself, if I recall.
Old Jan 24, 2026 | 03:18 PM
  #169
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
Your rants are stellar, and also very entertaining.
But, I also find myself agreeing with SW20S repeatedly.
When I see this thread posted in the new messages notification, I roll my eyes, thinking that surely, by now the topic has been exhausted of novel replies, let alone entertaining replies.
Now I have to break myself of this eyeroll reaction when I see this topic pop its head up like Punxsutawney Phil!
I can now see myself reacting with eager anticipation if I see new replies to the thread.
I know everyone is waiting with bated breath to know what my opinion is on the subject (please refrain from autonomic eyeroll).
But if you really want to know my opinion, investigate the likes I have cast.
I think I might have also replied with my opinion on the subject, not just a reaction to the replies.
Please keep the show on a roll!!!
Old Jan 24, 2026 | 04:56 PM
  #170
Yes I did have a 2022 AT, but cannot compare economy to the E53 wagon I replaced it with. I will say I do not notice wind noise in EL mode, which is how I drive it 95% of the time, and 75-80 MPH speeds do not adversely impact electric range.
You say real-world improvements are zero from 213 to 214 ATs. That’s the point…the article states they maintained Cd. Your new car has more frontal area with a wider body and wider tires. The EPA says highway economy improved with the 214, but even if it is the same, the aerodynamic tweaks were successful.
I believe the article is in reference to the 214 sedan, which is no less practical. The 214 wagon’s more tapering roofline could just as well have been an aesthetic decision, which I applaud…I think it looks fantastic and worth the shorter cargo area. My dogs would not agree, however.
Old Jan 24, 2026 | 05:06 PM
  #171
SW20S's Avatar
2024 S580
The door handles have no practical wind noise or fuel economy benefit lol
Old Jan 24, 2026 | 11:22 PM
  #172
Cao Black's Avatar
2015 ML350+2025 E350
If that's the case (not challenging, just saying), then they truly are an attractive but impractical gimmick. I did run into a funny situation concerning the retractables. Handed my visiting daughter the keys. She came back into the kitchen and asked how to open the driver's door.
Commenting on the topic of touch screens and complex menus, I find I can do most of those functions using "Hey Mercedes", or the talk button on the steering wheel. Hey Mercedes, what is the tire pressure? She'll reply, Let me check. The left front is... the right front is...etc., etc. Works for many many functions. Having to take your eyes off the road to navigate complex menus can be (is) distracting.
Old Jan 25, 2026 | 09:29 PM
  #173
Povitica3's Avatar
2022 C300 AMG-Line; 2020 E450; 2013 SLK350; 2023 EQS580
I do not own a W214, but drive an MB with these "suicide door handles".. I use the word "suicide" bcos more than once I have been lucky to quickly retract my fingers from its snapping jaws for whatever I did it deemed unworthy and hence must close... in those moments, I did a silent TY to whatever saved my fingers from been crushed.... our EQS580 is garaged, and 80% of the time unlocked. I did notice the times the door handle almost paralyzed my fingers were only when the car was unlocked as I walked to it. I have now changed to 100% locking the car, and have yet to feel endangered by it snapping off my fingers.... I guess I have been lucky, so far... knock on wood...
Despite all of the above, I am a huge fan of the new door handles. It is modern and truly fits the status of these new models. Am I crazy or what?
Old Jan 25, 2026 | 10:53 PM
  #174
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
Luckily, since your fingers didn’t get snapped off, you can still knock on wood!
It’s a lot harder without fingers!
Old Jan 26, 2026 | 11:30 AM
  #175
SW20S's Avatar
2024 S580
Yep, just a gimmick.
Yep, this is the "danger time". Its when you brush the door handle wrong and it thinks you want to lock the doors.
I'd be a fan if they worked better. Its just annoying also to walk up to the car and press and slide on the handles trying to get them to pop out.
