18x8.5/9.5 BBS LM Style wheels 20/28mm offset $549 *NEW*
Former Vendor of MBWorld
Description: BBS LM style wheels
We are excited to offer the BBS LM style wheels in low offset specially made with low offset in order to clear the big brakes.
WHEEL SPECIFICATIONS
Price: $549 Staggered
Offset: Front: 20mm Rear: 28mm
Weight: ~24lbs
Hub size: 66.6mm
Bolt Pattern: 5x112
Finish: Silver Polished Lip
Shipping: $85
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards.
Manufacturing Defect Warranty: The wheels are made in a low pressure casting process like OEM wheels do and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarantied to fit on your car without vibrations or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience knowing what fits your car. If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements. So we focused on putting the synergies in place that allows us to offer that service.
You can always call us at 248 686 2035 if you have any questions.
Thanks for looking!
2004 E55 AMG
Hi Wes,
I am not in a position to know for sure whether the ones on the cars pictured are real or not. I do know ours are replicas.
Just posted a few I found online to make it easier for people to visualize what some cars look like with that style wheels on.
Thanks AutoLuxury,
You can play around with tire sizes, depending if you wanted to keep it OEM recommended or if you like a stretch on them.
jonnyc, The lip does have a clear coat. Regarding factory caps, they don't work, but the wheels will ship with the BBS logos you see on the pic.
mobhouse,
That is awesome! Your car looks incredible with these wheels on!
Thank you so much for sharing. So TPMS transferred with no issues, stock bolts worked and cleared brakes without any problems?
Thanks,
mobhouse,
Thanks,
Don't have any tpms so didn't have to worry about that, but yea everything else went on without a hitch! Wheels do barely clear the calipers though! I'm used to that!
2014 E63s 1993 mazda rx7 on Boost
Mobhouse
Can you please take pic of the top looking down at both front and rear and also from the rear looking down the side of the car...I want to see the real offset..
They look like but small.... maybe if you lower the car or 19s...
