Bosch 550 injectors for E55 / CLS55 / SL55 / S55
Brand new, never used. Includes harness adapters. These are the EV14 injectors everyone uses and tuners are very familiar with.
If you're running a big pulley then you definitely should upgrade as your stock injectors are near their limit.
$280 shipped
$280 shipped
I believe stock is 40lbs. 550cc upgraded injectors is 52lbs.
The late model E55's have larger injectors from the factory. So it's clear the car benefits from it when AMG upgraded them even though the engine is making exact same power. Throw in modifications, and you definitely could benefit from larger injectors.
At a minimum it gives your engine insurance, and best cast you will make more power just from injectors because they will be operating in a more optimal range.
