EQS EQS (V297) sedan
Charging
Old Dec 17, 2022 | 09:10 PM
oghomwensule's Avatar
BMW
Charging
Just took delivery of EQS 580. Trying to use my previous tesla wall connector to charge using the Tesla Tap adaptor I got from Amazon. Charging is initiated then there is a click from the Tesla Wall Connector that interrupts the Charge. What am I doing wrong?
Old Dec 18, 2022 | 08:44 AM
babrams's Avatar
EQS 580
Charging
I have the 60 amp Tesla tap adapter which I use to charge my EQS 580 sedan. It works very well. I would check and make sure the adapter is securely attached to the cable. Mine is very tight to attach and remove. Also, be sure there isn't a 'Pause" time in affect when you try to charge. If there is, it will simply wait until the "Pause" time has ended. What color are the charging port lights when it stops?
Hope this helps.
Old Dec 18, 2022 | 11:38 AM
BMW
I finally got it to charge by disabling the eco-charging. Not sure why that made a difference
