EQS EQS (V297) sedan
Did MB update the battery management software?
Old Jan 27, 2023 | 08:10 PM
c4004matic's Avatar
17 E43; 21 GLS580
Just did a 185 mile trip at 65 mph at around 20 degrees, light snow and stiff winds and got 325 actual range! Surprisingly the AC eco function worked stellarly in its highest setting without a hint of fogging the whole way. Paint me very pleased.
Old Jan 29, 2023 | 03:10 PM
AppleFan1's Avatar
2025 EQS580
I had no idea about the ECO climate control increasing the range so much until you mentioned it here.
This morning, the temperature was a frigid 4 degrees here and and the car showed a range of 150 miles. As soon as I changed the climate control to ECO++, it shot up to 180 miles. And I noticed when I was driving that the range was decreasing considerably slower than when I had the climate control set to Comfort.
The air coming out of the vents was rather chilly since it was so frigid outside, but with the heated seat, it wasn’t bad. I’m going to experiment with ECO + next and let you guys know.
Old Jan 29, 2023 | 06:46 PM
stealth.pilot's Avatar
2022 Mercedes EQS 580
I have typically got fogging with eco+ but it may be seasonal. It's been a while since i tried it.
Old Jan 29, 2023 | 08:04 PM
AppleFan1's Avatar
2025 EQS580
I had zero fogging driving in the city for about 14 miles this morning with the outside temperature at 4 degrees.
Old Jan 29, 2023 | 08:15 PM
hlothery's Avatar
Veteran: Army
There would be no fogginess in my mind with those temps......I would be loading the UHaul, pointed South to warmer climes, and towing the EQS on a trailer behind. Wow, that is cold!!
Old Jan 29, 2023 | 08:42 PM
AppleFan1's Avatar
2025 EQS580
Actually, it’s more likely to fog with frigid temps. Your breath which has warm water vapor, will immediately condense in the cold windshield.
Old Jan 30, 2023 | 07:32 AM
sno's Avatar
sno
EQE 350+, EQS 450+, AMG C63
I tried it but since it was not cold outside it was warm inside the car. I did get an extra 25 miles, I also noticed that it lower the volume the radio and did a few other things to save power.
Old Jan 30, 2023 | 04:24 PM
AppleFan1's Avatar
2025 EQS580
I made error (first one in years &#128512 yesterday. Somehow, I mistakenly thought that there was an ECO++ on the climate control. No, there’s only comfort, ECO, and ECO+. At about noon today (10 degrees outside) I switched to ECO instead of ECO+. The range dropped by about 15-20 miles. The comfort setting drops it a lot more.
