2013 and UP Interior Upgrade on 2003 G500
Hello Everyone after messing up so many clusters and messing with AC conrol units and switch blocks I kind of figured out how to make them work on 2003+up G class However I should mention
that after these retrofits lots of error will be coming on on the cluster which Im still working on that to find a way to make them disappear
The whole process is not a clean job it will require lots wires ripping and splicing also the navigation feature will not work because on 2013 and up ( NTG 4.5) mercedes started to connect the maps on the comands to satelite so as soon as the comand picks up the new vin it will block the navigtion feature however if your unit is unlocked the dvd and phone BT will work just fine and u can connect your phone to listen to music
I will start uploading pictures soon and also will provide part numbers
Cheers
Cheers
