Defferential locks disengage
Old Aug 18, 2019 | 01:56 PM
icruise's Avatar
2009 G-500, 2013 Wrangler RUBICON
Hello,
The diff locks turns on (rear & front) fine, but they dissengage while driving in terain. Replaced the Vacum pump, still problem. Any isea someone?
thanks,
Old Aug 25, 2019 | 05:36 PM
icruise's Avatar
Anyone maybe?
Old Sep 2, 2019 | 01:31 PM
icruise's Avatar
Hi,
Just updating this morning I bleeded the lockers, oil came out a bit ugly, and then tested the car in terrain. Everything is working perfect, lockers engage after seconds, and dissangage almost immediatly. Lockares do not dissengage during using them by themselves. PERFECT! Thank you.
Old Sep 2, 2019 | 04:23 PM
paulunm's Avatar
2000 G500
What procedure did you use to bleed? Vacuum at the bleeders or pressure at the reservoir?
Old Sep 3, 2019 | 01:54 AM
icruise's Avatar
Started with just droping the oil out, little bit came out, then vacum it. Had no way to pressure it. Anyway, it is working better then new now. Vacum pump is working continuesly, probably some vacum leak, thats minor
Old Sep 4, 2019 | 08:39 AM
paulunm's Avatar
2000 G500
So you just opened the bleeder and enough came out?
Old Sep 4, 2019 | 09:08 AM
icruise's Avatar
I used a vacum tool after about 5 minutes.
