New "to me" 2017 G63
Looking good. I like it, nothing wrong driving this on during daytime for safety 😁
Thank you so much !
I also came across a picture of someone placing the LED light bar at the same location as yours but covered the entire middle section of bumper. Must be 30-40 in light bar. I will try to post a picture of it later.
Thank you so much !
i had a 30” in my Range Rover that I moved over to the G63 when I first got it in the fall...it’s just a little too wide to fit between the two verticals bars on the bull bar.... but fits perfectly under the bumper in that center slot!!! I go between having the bull bar on and off... when it’s off, I put the led bar here...
probably a 28 would fill out the space but then you can’t get a BD bar!!!
mrtonyn (04-01-2020)
It looks clean but most likely holes have to be drilled into bumper, versus using your clamps method.
Not a fan of drilling holes into any surfaces of the bumper or body so yours is the better option for me.
I have seen some retro, traditional, big, and round LED driving\fog lights that looks pretty good mounted on the bull bar as well.
#33
https://www.amazon.com/DJI-4X4-Driving-Wrangler-Warranty/dp/B081RN6G9R/ref=sr_1_15_sspa?crid=3KJH647Y3CMLJ&dchild=1&keywords=28+led+light+bar&qid=1585835726&s=automotive&sprefix=28%22+led+ligh%2Cautomotive%2C168&sr=1-15-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzSkVaNU4wNFhFTFVZJmVuY3J5cHRlZElkPUEwMjI3ODkwM1VEWjVGR0Y3UkRXSyZlbmNyeXB0ZWRBZElkPUEwNDY1MTk2MTFHTkE2RFAzSzI2MCZ3aWRnZXROYW1lPXNwX210ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
#34
The other method I was thinking about using (which may be what they did in the above pic) that doesn't require drilling a hole in the bumper, is using the two existing holes that are pre-made/drilled into the lower bar. I think it was already threaded for a bolt and then you could buy an LED that has these kinds of mounts vs a side mount.....just couldn't find one that was decent quality that used this kind of mount....
https://www.amazon.com/DJI-4X4-Drivi...NsaWNrPXRydWU=
You are correct, most quality brands are side mounted from my research so far.
Remember the retro round shape lights I was telling you that would look good also ?
Check out Clearwater Led lights.
#35
Looks awesome man love that color. Saw a similar color I saw one here on Long Island Ferrari dealer had it. I picked up a 14 over the summer. Slowly modifying it. Got way more planned.
How’s the taillights? I got those too but gave up wouldn’t work right/too much **** to put. I ended up going with mansory clear tails.
I did the same headlights as well and spacers gave it a miner lift.
curious to see the facelift steering go in
#36
What you use to blacks the back tire? That’s my next thing and the side chrome thing maybe in CF vinyl I was thinking
you should do the brabus lower lip too with the LEDs
#37
I had a local place powder coat the spare tire ring...I have an extra one already blacked out if you are interested! Just PM me! Next for me is the side steps and muffler tips!!!
