W463A side reflector delete trim
Old May 4, 2020 | 03:38 PM
abhatti55's Avatar
'19 G63 Ed 1,'18 M5, '16 G63,'12 458 , '11 E63, Brabus SL55-K8, '10 S63, '94 E500 "Wolf", '91 560SEC
Has anyone been able to source this or have part numbers? The blackout film helps but would prefer just getting rid of them.
Old May 4, 2020 | 06:47 PM
drew138's Avatar
993 TT
x2 same here. I had someone try to find out and they were shut down by MBUSA. Wouldn't even give them the part # and the said dealers overseas have been told to not export of them or something. I was planning on calling a bodyshop in UK and asking them for a part # but need a EU VIN. Anyone overseas with a G63 want to help!
Old May 4, 2020 | 06:56 PM
hjsyyc's Avatar
740il
I have mine vinyl wrapped in black gloss. Turned out like OEM. Also know they can be removed and gloss spray painting will work too.
Old May 4, 2020 | 07:04 PM
drew138's Avatar
993 TT
mine are blacked with tint. i'd still like to replace them with OEM euro style. it bothers my eyes to see the bump
Old May 4, 2020 | 10:36 PM
Festertester's Avatar
‘13 911-4S, ‘21 CTR, '22 GT4, ‘19 G63
I’m getting mine blacked tinted / wrapped as well. It’s amazing how the look improves by just blacking these out..
Old May 5, 2020 | 08:30 PM
jerrym's Avatar
1955 300SL
pics of before and after please!!!
Old May 6, 2020 | 03:10 AM
JATT63AMG's Avatar
MY19 G63 AMG
My tinted wrap
Old May 6, 2020 | 09:42 AM
Bob Z.'s Avatar
'27 EQG deposit, '22 F8 Spyder, '20 Fat Boy
Do they come off? If so that may make it easier to tint or wrap.
Old May 6, 2020 | 09:44 AM
Tristanyeo's Avatar
G63
#A4636986701 Left front trim item95
#A4636987201 right front trim item95
#A4636988101 left rear fender trim item145
#A4646988601 right rear fender trim item145
Old Jul 31, 2020 | 10:25 PM
Bob Z.'s Avatar
So I have replacement side trim in solid Black so I can replace the pinstriped pieces and reflectors; however, how do they come off? I am referring to the 1/2" high inner trim, not the entire side trim. I looked at the parts diagrams and they do not show how they are held on but I am guessing with double-sided tape.
Old Aug 1, 2020 | 09:42 AM
pateljb's Avatar
2009 S550 4Matic 2009 GL 550 2009 AM DBS
It's definitely double sided tape. My detailer removed the reflectors to spray tint them.
Old Aug 1, 2020 | 09:48 AM
Bob Z.'s Avatar
Perfect, thanks, and I assume that all the inner trim strips along the side are applied with tape as well!
Old Feb 8, 2022 | 12:57 PM
Pst_pnk's Avatar
G
Anyone use this?
Reviving this
I wanna do the same thing and completely remove the reflectors
Since it’s difficult to source this from overseas Mercedes-Benz parts has anyone used the aftermarket versions available on eBay?
Here’s a link to one that lets you choose AMG or black for the small strip between the door and front fender
Some sets don’t come with adhesive backing, Not sure if this is a plus depending on what’s left underneath from removing the other strips it might be easier just to glue the new set back in. Any thoughts on that are appreciated from those who have done this
Let me know if anyone has experience with this or has other options to look to.
https://www.ebay.com/itm/G-Class-NEW...-127632-2357-0
Old Feb 8, 2022 | 01:13 PM
Bob Z.'s Avatar
You are going to want to remove all of the old adhesive residue before installing new ones - take it from someone that did this, and had to buy a 2nd set because I did not remove it all the first time. It will look ripply/wavy if you do not so you need to have a perfectly flat area. I used an adhesive remover wheel, which worked well albeit it was a lot of work.
Old Feb 8, 2022 | 01:59 PM
Pst_pnk's Avatar
G
Great tip
Very Helpful
Thanks Bob
