10mm or 15mm spacers needed
Old Apr 2, 2021 | 09:27 AM
marcolarco52's Avatar
homeless
As the title states looking for 10mm or 15mm spacers for my 21 g63, same bolt pattern and bore as previous gen 5x130 with 84.1mm center bore.
Any help would be appreciated.
Cheers
Old Apr 2, 2021 | 11:28 AM
streborx's Avatar
Top Answer: 1
G550
Cheers
You can find universal fit spacers at most auto stores. If you're looking for a G custom fit and want to spend more money, try H&R (www.trakplus.com).
Old Apr 2, 2021 | 12:19 PM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
The G wheels, like all MBs, are hub-centric so you should only use spacers specifically machined for the G. Many "universal" spacers are either not truly hub-centric or are machined to sloppy tolerances. Make sure you also adjust the lug bolt length to correct for the thickness of the spacer.
Old Apr 2, 2021 | 12:49 PM
homeless
OK that makes sense then I'll avoid cheap online ebay spacers as I don't want any wobble or shaking at higher speeds. I'm located in Canada so it makes it a bit harder to find online here.
Old Apr 2, 2021 | 04:33 PM
streborx's Avatar
Top Answer: 1
G550
BTW, the OE wheel bolt size is M14-1.5 x 64mm (threaded portion is about 20mm) w/radius seat, so add your spacer thickness to 64mm. Some parts databases erroneously spec M12.
Old Apr 3, 2021 | 11:09 AM
streborx's Avatar
Top Answer: 1
G550
Supplemental FYI: Trakplus (a.k.a. H&R) also sells MB compatible wheel bolts -- the website has info on how to measure for the required extra length.
Old Apr 3, 2021 | 08:04 PM
homeless
Going to visit the wheel shop that sold me the previous wheels see if they can help out sometime soon and if not I'll get in touch with Trakplus only thing is being located in Canada with the border being closed it makes getting things a bit more difficult
