Remove rubber trim on W463?
Old Jun 28, 2021 | 10:54 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
Does anyone know how to, or are there any guides, on removing the rubber door trim on the G-class? A picture is posted below showing which piece that I am referring to.
Thank you.
Old Jun 29, 2021 | 12:56 AM
084runnerltd's Avatar
2021 G550, BMW X5M, 2020 Toyota Supra LE
I know people have had there rocker panels painted….regarding moving the rubber. It is (very) tightly slide into rails that hold the rubber.
If I recall, the last person who had this done was charged 4 hours of labor by the paint shop to remove and replace the rubber after the painting was complete.
I have the night package plus option and everything on my G is dark, except these dang rockers…:let me know if you find a simpler solution.
Good Luck
Old Jun 29, 2021 | 02:54 PM
JD101b's Avatar
Damn. But thank you for the info.
I have the original W463 so it may be different than yours. We will see.
Old Jul 1, 2021 | 11:04 AM
rudys_500's Avatar
2002 G500 thulit red
its a lip covering a dozen screws beneath - a 5 minutes job
Old Jul 1, 2021 | 11:25 AM
Congrats OP, looks like you are in luck!!
Old Jul 1, 2021 | 04:03 PM
JD101b's Avatar
Yes, but how do I remove the lip? I tried examining how to do so but it is quite firmly in place.
Old Jul 2, 2021 | 08:14 AM
rudys_500's Avatar
starting at one end using something small like screw driver to push it outwards.
you might wanna clean it first and/or use warm water to soften the rubber.
Old Jul 2, 2021 | 08:16 AM
JD101b's Avatar
You mean just pry it off? Is it easy to snap back into place?
Old Jul 3, 2021 | 02:20 AM
rudys_500's Avatar
yes and yes
Old Jul 3, 2021 | 11:25 AM
JD101b's Avatar
Is there any adhesive?
Old Jul 5, 2021 | 11:32 AM
rudys_500's Avatar
no
