Fire extinguisher mount
Old Sep 15, 2021 | 02:21 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
Is there a place to mount a 3-5lb fire extinguisher in the G-class? I've seen them mounted on the floor under the passenger seat but I'd rather not drill into metal (another point of rust lol).
Old Sep 16, 2021 | 04:53 AM
streborx's Avatar
Top Answer: 1
G550
First Alert markets a compact fire extinguisher in a 14 oz. aerosol can that fits into a door pocket, cup holder, or other small space. Not sure what size fires you want to mitigate, but this bottle beats nothing. I recall seeing a Youtube demo regarding its capability.
Old Sep 16, 2021 | 12:20 PM
JD101b's Avatar
I have a few cans of those actually. I keep them in a plastic trunk in the back of the truck. Costco was selling 12 packs for something like $40. I used one once to put out a fire in my fire pit (I wanted to see how effective it was). Worked pretty well but you have to be within 5 or so feet of the fire. A regular extinguisher can has a much more powerful stream.
I ended up putting a 4lb extinguisher in the netting under the passenger footwell.
I think I am going to mount a bracket in the rear cargo area to the right of the door (underneath where the rear park sensor indicator is). There is nothing solid to drill into besides the plastic trim, but I think it should hold a 5lbs extinguisher nicely.
Old Sep 18, 2021 | 01:13 PM
RossoLinea's Avatar
2008 G500
I've been fabricating a lot of things for my G500 and one is a fire extinguisher mount. In this case, I designed it to mount using the factory bolts (so no drilling).
Old Sep 18, 2021 | 02:41 PM
JD101b's Avatar
oh, that looks great [
QUOTE=RossoLinea;8420185]I've been fabricating a lot of things for my G500 and one is a fire extinguisher mount. In this case, I designed it to mount using the factory bolts (so no drilling).
[/QUOTE]
