2015 G63 shuddering
Old Oct 30, 2021 | 07:09 PM
bonz's Avatar
17' C300 Coupe
2015 G63 shuddering
Just recently started. First check engine light, ECO mode stopped working and the engine is idling a little erratically (possibly misfiring 1 or 2 cylinders) and in drive its got a shudder/shake to it.
Obviously i need to have an obd scan it.
But before that, anyone else have any similar issues?
TIA
Old Oct 30, 2021 | 11:33 PM
PKE55AMG's Avatar
06 E55 AMG (my dailydriver)
Exact same problem but on MY 2018 G63. But mine only occurred in the morning on first start when everything was cold. Once engine was warm symptoms were gone. Solution: Dealer did a software update and all is good. Hope this helps.
Old Oct 31, 2021 | 06:18 PM
streborx's Avatar
Top Answer: 1
G550
Shudder and shake? Your truck got news of what new Gs are selling for (lol).
Old Nov 1, 2021 | 02:24 PM
hard top's Avatar
2012 Land Rover LR4 5.0L V8 LUX HD
Shooting from the hip in the dark, check the coil packs.
Old Nov 1, 2021 | 04:16 PM
bonz's Avatar
17' C300 Coupe
I was trying to avoid going to the stealership, but if it comes to it, i may have to.
Thanks man.
Haha yeah something like that.
350 to 400k AUD in Sydney, Australia
Was thinking the same...coils.
I assume they change the spark plugs for a B service?
Which was just done around July.
Old Nov 2, 2021 | 08:04 AM
bonz's Avatar
17' C300 Coupe
Turned out to be Coil no.7
Is this a common issue with these motors?
Old Nov 2, 2021 | 01:46 PM
newbieG63's Avatar
2015 G63
I happen to have the same exact issue that just started. I also have a new to me 2015 G63 with 35k on the clock. Usually engine is cold but settled at idle. Transmission upshifts to higher gears at low speeds and then hard shuddering that sounds like misfiring. Sometimes I can shut it down and restart and it resolves. Eventually the issue goes away on longer drives. Thanks for the hints that it may be coils. Have it scheduled at a MB tech, not stealership. Am I damaging the engine by driving it in the mean-time?
Old Nov 2, 2021 | 05:15 PM
bonz's Avatar
17' C300 Coupe
Yeah does sound similar.
Except shutting it down didnt help for me. The coil was just completely out of commission. Almost like it arced.
Had a bosch coil fitted instead of oem.
I did drive it like that to the shop 10 minutes away.
Whether its harming or not, it did feel like it was labouring the transmission a bit.
Short drives though should be ok but not continual.
Old Nov 3, 2021 | 09:23 AM
newbieG63's Avatar
2015 G63
Thanks @bonz
Old Nov 6, 2021 | 10:24 AM
newbieG63's Avatar
2015 G63
My fault code showed issue with ignition coil and spark plug on #6. Changed both out myself and all good now. Thanks to this forum I knew where to order parts and how to fix myself and saved a ton of $$
Old Nov 6, 2021 | 11:53 AM
streborx's Avatar
Top Answer: 1
G550
Might I ask what OBD code reader you have? I want to acquire a new one (have been looking for a year now). They're all made in China, they all look as if they come from the same factory, each brand is littered with dozens of models and prices, all claim to be best, and all get complaints in reviews. I bought a Foxwell NT530 a couple months ago and sent it back the same day when it was unable to connect and download an update. I don't need to reprogram ECUs -- just read MB codes.
Old Nov 7, 2021 | 08:29 AM
newbieG63's Avatar
2015 G63
My Mechanic friend used this Launch scanner to help me diagnose which cylinder I had the issue. I need to buy a scanner myself and found this one on FCP Euro, the same place I bought the replacement Bosch Ignition Coils and plugs. There are lots of scanner options above and below that price point.
https://www.fcpeuro.com/products/aut...er-autel-al629
Good luck!
