Replacing Headlight
Old Jan 17, 2022 | 04:07 AM
DVR's Avatar
DVR
2016 AMG G63 (W463)
Replacing Headlight
On a recent 4WD trip I managed to catch a stone that smashed the glass on the LHS headlight of my 2016 G63. MB Aust have quoted A$3500 for a replacement unit . The headlight still works but the glass is cracked and missing a small piece. Has anybody have any experience with replacing a W463 headlight? There appear to be aftermarket HID options available that are significantly cheaper than an OE replacement. Is it possible to replace the glass/bulb component without replacing the whole unit or is there a 'repair' option available? Any thoughts are most welcome.
Old Jan 17, 2022 | 09:45 AM
Limey Hooligan's Avatar
2012 G550 - Capri Blue Metallic
Pretty easy to remove the headlight from the front. I think you would have to replace the whole unit, and like you say there are a few LED and other aftermarket options out there. Just depends on your budget and desire for OEM parts along with your tolerance for replica parts made in China (I have some myself). . If you search the forum you should find some options and discussions.
Old Jan 17, 2022 | 01:56 PM
mercforhire's Avatar
2011 G55 AMG
Take a picture and post here. Hunt for a used headlight from your local Cragslist and Ebay
Old Jan 17, 2022 | 09:58 PM
z168's Avatar
3phase-4pole
There are a few options:
1. click
2. click
Old Jan 17, 2022 | 10:01 PM
z168's Avatar
3phase-4pole
after looking at new genuine units that almost approximate the cost of just the lens, I would go the route of just replacing the whole thing
Old Jan 18, 2022 | 10:24 AM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
Removing the entire headlight unit is relatively easy - a 10 minute job really.
You can always look on eBay for used units. If you purchase from a longtime seller with a good rating, you should be safe.
Old Jan 24, 2022 | 01:22 PM
rhungent's Avatar
2015 G63 AMG, 2014 ML350
Changing the headlight takes only 30min (first time).
I happen to have a used headlight from my 2015 G5 with 64,000k miles. Its original factory with strong glass lens.
I listed it on Ebay for $584. Much less than getting a replacement from the dealer.
https://www.ebay.com/itm/30429846635...wAAOSw~rhh35tJ
Old Jan 24, 2022 | 03:45 PM
z168's Avatar
3phase-4pole
how hard is it to replace the peanut bulb below the main beam? I probably need to take out the headlamp assy out, right?
Old Jan 24, 2022 | 10:12 PM
PeriodCorrect's Avatar
2011 G550
I hate that little yellow light. Need to find an error free replacement that will be LED or at least white in color.
Old Jan 25, 2022 | 09:27 AM
JD101b's Avatar
That is correct, yes.
